Author Topic: Deadpilot's Whited Out Convert "The Beast"  (Read 83650 times)
Re: Deadpilot's Whited Out Convert
« Reply #150 on: May 10, 2015, 01:21:44 PM »
So after yesterday test drive I found out I still have some brake issues that need to be fixed. Parts are on order to repair the caliper on passenger side and some more brake line fittings to fix a few leaks.  I also have to see what the shift linkage is hitting to see why I can't shift in rear high now.  Then I think figured out the vibration noise I'm getting from drive train. I think it's cause the transfer case is hard mounted and the rest is soft mounte. So I'll be ordering parts to fix that problem soon.
« Reply #151 on: May 13, 2015, 04:47:28 PM »
Well its official my X is 4x4 now! I just installed the front drive shaft so everything is connected. Now just have to fix the brakes.
« Reply #152 on: May 13, 2015, 08:22:21 PM »
Nice Job, Have you done the hard mount yet??
« Reply #153 on: May 13, 2015, 08:35:07 PM »
Well the hard mount isn't the best idea from the reading I've done. Since the motor isn't hard mounted. I'm looking into how the 4x4 mount the transmission
« Reply #154 on: May 13, 2015, 09:05:31 PM »
nice
« Reply #155 on: May 14, 2015, 11:23:19 AM »
Looking good Jason!  4x finally!
Sent from Planet Claire
 using Tapatalk
« Reply #156 on: May 14, 2015, 12:12:06 PM »
When are you going to test it?
Re: Re: Deadpilot's Whited Out Convert
« Reply #157 on: May 14, 2015, 03:48:26 PM »
Don't know yet.
 using Tapatalk
Thanks it's taken forever lol.
« Reply #158 on: May 14, 2015, 03:52:25 PM »
So since I could do much work cause of the weather I worked on front end.  I got all the lights hooked back up and winch is back up and running. Also got the ARB compressor mounted with the other thing to for the locker and on board air hook up.
SteeevO
  • 4wd Pts: 22
« Reply #159 on: May 14, 2015, 05:27:02 PM »
We're going to the hammers when it's done right?
« Reply #160 on: May 14, 2015, 07:05:32 PM »
I'd be down with that.
SteeevO
  • 4wd Pts: 22
« Reply #161 on: May 15, 2015, 09:23:54 AM »
We should get more people together to go play out there too!
Keep us posted on the build
« Reply #162 on: May 15, 2015, 09:29:22 AM »
That would be fun. Once I'm ready to go out there I'll let everyone know and we can plan something.
Next week I'm going to try fix my brake issues and also my drive train wobble. Then I can deal with all the warning lights lol
« Reply #163 on: May 15, 2015, 02:12:35 PM »
http://i906.photobucket.com/albums/ac265/netwaytech/Electrical%20Tape/250-250-ElectricalTapeS99Black.jpg
Problem solved.  :D
« Reply #164 on: May 15, 2015, 03:21:25 PM »
C'mon John, don't insult all of Jason's hard work doing this project from scratch.
It's a beautiful X. He needs to use white tape for his whited out X  ;D
