Author Topic: SoCalXTerry Build  (Read 81123 times)
Re: SoCalXTerry Build
« Reply #180 on: June 02, 2014, 11:10:14 AM »
ouch... I'm sure you can get her  back into it slowly.
I'm glad you guys are both physically alright.
« Reply #181 on: June 02, 2014, 02:12:56 PM »
Thank you for that Tom.  No I got her right back in the saddle  ;)  We did Fins & Things that afternoon and Elephant Hill the next day.
« Reply #182 on: June 02, 2014, 03:24:23 PM »
 Right back in the saddle is an understatement, Terry is being modest here guys. You should have seen him on Tip Over Challenge... that guy can wheel. Then of course not to be outdone his brother says "Well if he did it twice" and procedes to follow on up. Those guys are a hoot when they are together.
« Reply #183 on: June 02, 2014, 03:35:21 PM »
I wish I would've been there.
« Reply #184 on: June 02, 2014, 03:40:03 PM »
 That whole trip from start to finsih was a blast, there is always next year!
« Reply #185 on: June 02, 2014, 04:01:31 PM »
You HAVE to go there at least once Tom.  It is too fun for words.
« Reply #186 on: June 02, 2014, 09:09:39 PM »
It's on my list for sure.
« Reply #187 on: June 09, 2014, 01:17:07 PM »
DID you have to do anything special for the Fabtech lift, and did you have it professional installed of did you do it yourself.
« Reply #188 on: June 09, 2014, 03:02:40 PM »
There in lies a long story.
Too make it short:
  Front is supposed to be bolt compatible across the board.  Rear I had to go spring over Axle.  So there is some fabrication involved.  Move spring perch and lower shock mounts.
  So with the fabrication involved decided to have a "professional" installer do the work.
  Again long long story short it was screwed up royally.  Many things done wrong.   Even so far as rear leafs removed to make the back end of the truck lower.
 If I were to do it again.   I would probably do the front end myself.   Because if you can follow directions it IS truly bolt compatible.   And then find a welder to flip the spring over axle or buy a special leaf pack with the arc built in to give you the extra 6" of lift.   But remember if you go 6 or more inches you NEED to replace the drive shaft.   The OEM drive shaft will NOT handle it and because of the angles a Double Cardon drive shaft is preferable.
There my experience in a nutshell.
« Reply #189 on: June 09, 2014, 04:46:30 PM »
well I am just three inches, dont want do the blue crap.
Re: Re: Re: SoCalXTerry Build
« Reply #190 on: June 09, 2014, 08:35:00 PM »
Ladies and Gentlemen, Under statement of the month.
« Reply #191 on: June 27, 2014, 04:25:28 PM »
Two weeks ago, Pilot trail claimed a victim. Terry split his steering rack and poo-poo'd the trail.
    Luckily, I happen to have one of these.
No joke! In my garage. Brand new!
Today, we got an early start. Terry rolled into my place at 0600.
    by 0730, we gave birth....
The rack separated from itself.
   Check out the middle section on the upper one. You can see the piston.
    A little while later
   This was an absolute cake walk! Took us less than 3 hours with a good break for coffee. The biggest pain in the ass was getting the tweeked rad skid back on. Seriously.....it sucked!
  One quick test drive and all is well! Smell ya' later.
chrishaynesusa
  • thenewx
  • 4wd Pts: -35
« Reply #192 on: June 27, 2014, 06:56:46 PM »
^^^^^you are a swell guy.
the Xterra community is lucky to have you and I am proud to have drank a beer with you.
good on ya !! :)
« Reply #193 on: June 27, 2014, 09:49:01 PM »
X2
Nice work gents
« Reply #194 on: June 27, 2014, 10:06:45 PM »
Glad to see ya up and running again.
