Author Topic: SoCalXTerry Build  (Read 81125 times)
Re: SoCalXTerry Build
« Reply #195 on: August 18, 2014, 11:38:48 AM »
Well after breaking two sets of the plastic I did it.   They are custom from InSain Fabrication:
https://www.facebook.com/InSainFab
Actually think they came out really nice:
http://i866.photobucket.com/albums/ab225/socalx46/Truck%20modifications/New%20Rear%20Corners/2014_08_18_1051_zpsca4b1b35.jpg
SoCalXTerry Build
http://i866.photobucket.com/albums/ab225/socalx46/Truck%20modifications/New%20Rear%20Corners/2014_08_18_1050_zps08c589b1.jpg
SoCalXTerry Build
http://i866.photobucket.com/albums/ab225/socalx46/Truck%20modifications/New%20Rear%20Corners/2014_08_18_1045_zps3c937167.jpg
SoCalXTerry Build
chrishaynesusa
  • thenewx
  • 4wd Pts: -35
« Reply #196 on: August 18, 2014, 08:05:41 PM »
do they fit a STOCK mount area?
can they be ordered off of their web site?
how much?
« Reply #198 on: August 18, 2014, 09:53:12 PM »
Terry, they should really use your photos (or photos of your install) because the ones the have on the Nisstec site look not so awesome
Yours however, do look awesome!
« Reply #199 on: August 19, 2014, 05:29:16 AM »
Hi Chris,
Yes it takes some trimming from the rear wheel well about 1 1/2, I used an angle grinder to do it.
Website???
His name is Corey Sain.  "They can contact me at (704) 651-6871 or on my FB page InSain Fabrication"
how much?
His quote: "I'm looking to sell powder coated and shipped for $750. Thanks"
« Reply #200 on: August 19, 2014, 05:47:47 AM »
Those nice. I wonder how well it will take at hit.
What's the weight of it and how thick is the aluminum?
How's do they compare to ones I made?
« Reply #201 on: August 21, 2014, 04:46:10 PM »
Well I guess I will find out.  That was what they wanted me to do.
Don't know the thickness exactly.  I think it is 1/4"
« Reply #202 on: August 23, 2014, 08:04:26 AM »
Nice corners Terry...props to Nisstec for promoting and stocking a lot of Xterra aftermarket parts.
« Reply #203 on: September 09, 2014, 05:17:45 PM »
Well electrically I'm loaded for bear.   Plenty oh power for my upcoming adventures:
http://i866.photobucket.com/albums/ab225/socalx46/Truck%20modifications/NewBattery_zps5dc018fd.jpg
SoCalXTerry Build
Toro, the other one fits with room to spare:
http://i866.photobucket.com/albums/ab225/socalx46/Truck%20modifications/Battery-box_zpseb1346e7.jpg
SoCalXTerry Build
SteeevO
  • 4wd Pts: 23
« Reply #204 on: September 10, 2014, 01:51:01 AM »
Dual batteries is one of the best thongs that someone can do to their rig for being out for days on end. Terry, have you considered a small solar battery maintainer as well?
« Reply #205 on: September 10, 2014, 05:16:16 AM »
Yes I have.   Are you aware of any that are small enough but provide enough output?
« Reply #206 on: September 10, 2014, 08:44:27 AM »
Terry, can you give a little more info on the Odyssey battery and where you plan to mount to Optima?
« Reply #207 on: September 10, 2014, 04:00:38 PM »
Yes sir I'll try.   The Odyssey is touted as the best battery you can buy on the forums.  I do understand though that the Diehard Platinum from a number of sources is supposed to be the same battery as the PC1500.  So it would be your choice, I suppose.
I have run an Optima Yellow top for about a year and a half now.   I originally intended to put the Odyssey back where the spare tire was.  Well the Odyssey is bigger and much heavier  (Don't know if that translates to quality or not) than the Optima.   So I decided to put the Odyssey up front (Had to do the old battery terminal extension mod it wasn't an R type) and put the Optima back as the secondary.  It will work out much better I think lighter and smaller.   But we shall see there is still some fabrication ahead.
« Reply #208 on: September 10, 2014, 08:50:18 PM »
Ah, thank you sir.  I know my buddy Joseph (soulcontrol on here) has mounted two optimas in the back on each interior side of his frame.  From what I understand, He used a fairly off the shelf battery box to mount them there.  His are mounted sideways, terminals on each pointing towards the interior of the vehicle.
I'll ask him what he's using for mounting and maybe to snap a pic if you're interested.
« Reply #209 on: September 11, 2014, 12:09:28 AM »
Yea frontys have a ton of extra room under the bed, we are not as lucky.
