Author Topic: SoCalXTerry Build  (Read 81228 times)
Re: SoCalX_tl11 Build
« Reply #30 on: September 12, 2012, 11:23:47 AM »
Definitely needs 35s
« Reply #31 on: September 12, 2012, 11:56:40 AM »
Thank you Marshann for posting the picture...I just did that too and put the pic in Terry's original post/link.
« Reply #32 on: September 12, 2012, 02:02:51 PM »
ok teach me guys.   I did the insert image ""    and then pasted "https://www.dropbox.com/s/t5u5uq1a9epnqpg/myx.jpg
"  between the img comands.   So what did I do wrong?
I'm so proud of myself  ;D ;D   Thanks John
« Last Edit: September 15, 2012, 09:42:31 AM by SoCalX_tl11 »
« Reply #33 on: September 12, 2012, 04:02:58 PM »
Terry...the pictures won't load as an image file directly from your DropBox account.
Creating a Photobucket account, then uploading the pictures there is a better method.
Then, access your Photobucket account and click on the image code in the box below the photo, and it will say "copied".
Then, paste the image in the "reply" box here with the image codes around it.  That should help and make photo posting easeir for your in the future.
« Reply #34 on: September 15, 2012, 09:42:53 AM »
Actually figured it out.   Dropbox uses an ssl secured URL  https:\\   and the others photobucket et all use a regular URL  http:\\
Thanks again
« Last Edit: September 15, 2012, 10:30:48 AM by SoCalX_tl11 »
« Reply #35 on: September 23, 2012, 10:54:26 AM »
Just a little fun obstacle at GoneMoab 2012:
RockinX
  • 4wd Pts: 33
« Reply #36 on: September 23, 2012, 01:54:06 PM »
Great picture Terry and on your 100th post!  Does that obstacle have a name?
« Last Edit: September 23, 2012, 03:16:43 PM by RockinX »
« Reply #37 on: September 23, 2012, 04:39:49 PM »
Did you make it up that?? That's a great pic!!
« Last Edit: September 23, 2012, 04:42:03 PM by HEVAK »
« Reply #38 on: September 23, 2012, 08:18:30 PM »
No just one of many on the trail called Metal Masher in Moab.   This make 101? ;D  Talkative aren't I.
« Reply #39 on: September 23, 2012, 08:20:57 PM »
Thanks.   Why yes I did.   Actually that particular line there were only one or two of us that did make it up that thing.
« Reply #40 on: October 02, 2012, 06:43:19 PM »
This is called the Wedgy on Poison Spider Mesa going down:
and this is going the other way   :P
« Last Edit: October 02, 2012, 06:45:10 PM by SoCalXTerry »
Lava
  • 4wd Pts: 21
« Reply #41 on: October 02, 2012, 07:02:22 PM »
LOVE THAT FRONT BUMPER!
My other vehicle is an X-WING
Justin - KK6JEC
occupantX
  • 4wd Pts: 65535
« Reply #42 on: October 03, 2012, 10:16:08 PM »
NO TITAN SWAP!!!!   6" Fabtec Suspension lift which included going Shock over Axle in the rear.    Thanks to Justin...   I think I'm getting more than 6" of total lift.
Which Fabtec kit is this? I'm only finding Frontier and Titan kits, do they have X kit?  And who's Justin, a workshop you can recommend?
Did you get the ARB locker from RuggedRocks?
« Reply #43 on: October 04, 2012, 05:25:23 AM »
It is the Fabtec Frontier Lift kit.   To my knowledge so far OZ, Mastagrog and myself have installed them. The front axle cross-members and such are bolt compatible between the X and Frontier.  The difference is the Rear Axle.   The X is spring under axle and the frontier is spring over axle.   So Justin at AOE flipped my X to Spring Over Axle to get the added height. Had to weld new spring perches, relocated my lower shock mounts, kept my longer shackles and AAL from PRG and used the longer shocks from the Fabtech Kit in the rear.    A word of warning!!!  The driveshaft has to be lengthened...  Don't waste your time if you aren't willing to go to JE REEL in Pomona and get a Double Cardon drive shaft fabricated by them.  They have a lot of experience with lifted Xterra driveshafts.
My front ARB locker and compressor came from RuggedRocks.   With regards to the front locker.   Find a competent experienced well-referenced installer.   Lockers have not been installed in the R180 for very long and it takes real skill to get it right.  I can give you an option if you want
« Last Edit: October 04, 2012, 07:08:13 AM by SoCalXTerry »
Re: SoCalXTerry Build
« Reply #44 on: October 04, 2012, 07:42:38 AM »
And it only took 3 months..
You tired of driving that beater and riding shotgun everywhere?
