Author Topic: SuperSlideStyle  (Read 72512 times)
Re: SuperSlideStyle
« Reply #90 on: February 19, 2021, 12:01:37 PM »
Getting ready to install a used set of PRG UCA bought from Jayrat!  Just waiting on new 14x1.5 120mm bolts to arrive.
Re: SuperSlideStyle
« Reply #91 on: August 01, 2021, 10:46:09 PM »
Got an $87 snorkel from ebay, made for a Jeep Cherokee, modified to fit on my X.
« Last Edit: August 01, 2021, 10:50:39 PM by SuperSlideStyle »
Re: SuperSlideStyle
« Reply #92 on: August 01, 2021, 10:51:15 PM »
Re: SuperSlideStyle
« Reply #93 on: August 01, 2021, 10:53:02 PM »
Re: SuperSlideStyle
« Reply #94 on: November 23, 2021, 10:26:42 AM »
Nee CSF 3-row all aluminum radiator being put in.
Re: SuperSlideStyle
« Reply #95 on: November 23, 2021, 05:36:47 PM »
Thats pruutty
Re: SuperSlideStyle
« Reply #96 on: January 10, 2022, 04:06:16 PM »
New rear bumper & tow hitch coming soon...
Re: SuperSlideStyle
« Reply #97 on: January 10, 2022, 04:56:51 PM »
Looks good, curious why you didn't just weld in the hitch and recovery points around the original bumper? Either way I think it looks great
Re: SuperSlideStyle
« Reply #98 on: January 10, 2022, 05:14:30 PM »
How are you liking the New Radiator ??
Bumpers looking good, Just a little bit of welding to go  :'(
Re: SuperSlideStyle
« Reply #99 on: January 30, 2022, 06:06:11 AM »
Truck runs CONSIDERABLY cooler, especially with the 3 big hood vents, Mishimoto thermostat, Nismo radiator cap & blue silicone radiator hoses.  I also doubled up on all the hose clamps to whithstand the higher coolant pressures.
« Last Edit: January 30, 2022, 06:08:54 AM by SuperSlideStyle »
Re: SuperSlideStyle
« Reply #100 on: February 04, 2022, 07:08:53 PM »
Almost done welding in gussets & internal framework.  Then I can start on the double-swing arm...
(Yes, the welds are ugly, some have several passes... but it's mostly 3/16" & ΒΌ" steel.  I'm making sure the weld is penetrating.  Otherwise, it won't be strong.  Looking for strenght, not beauty.  Ok, here come the criticrsms, the memes, etc...)
« Last Edit: February 04, 2022, 07:12:36 PM by SuperSlideStyle »
Re: SuperSlideStyle
« Reply #101 on: April 22, 2022, 03:53:32 PM »
OK this sucks but somehow it happened again.  The timing chain jumped a tooth again.  This is the 3rd time I'll be re-doing this on my X.   But with help from Clark over at Jim Wolf Technologies in El Cajon, CA, I was able to find some interesting facts about the VQ40DE and similarities with the Skyline  GT-R VR38DETT engines built by Nismo's Takumi division.  (JWT is currently building several IMSA race-class VQ40DE motors for Nissan).
1.)   Everyone knows that the early 2nd genic steroids add bad timing chains and timing chain guides and tensioners.   Because Nissan shares the VQ blocks with the 350Z, 370Z, rare JDM Juke-R, Skyline GTR, Pathfinder, Frontier and Xterra's, they all have interchangeable parts for the engines.
2.)   The pictures below shows a Nissan Skyline timing chain and main timing chain guide compared to an aftermarket replacement.  Notice the additional gussets and beefiness of the newer OEM units compared to aftermarket parts.   The  OEM Nissan Skyline VR38 timing chain is also beefier & slightly heavier that the aftermarket timing chain.  JWT alsp said that the '03-06 350Z VQ35DE (and VQ35HR) parts flow more oil & have improved cooling, starting the that head gasket designs.  That a Tech Support bulletin that shows very detailed pictures on where to grind away aluminum for improved cooling, head gasket differences between the many engine block models and even the type of head bolt that should be used.
3.)  Also pictured is a new Stillen Racing Aluminum main pulley for both VQ35, VQ40 & VR38 motors.   Available as a standard-size replacement or an undersized version (which requires a smaller diameter of serpentine belt, yields 1-2hp more).  The difference is quite literally 1/2 lb vs. 16 lbs of rotating mass, good for 3-4hp/5-6 ft. Lbs of torque.
Re: SuperSlideStyle
« Reply #102 on: April 22, 2022, 03:54:37 PM »
Re: SuperSlideStyle
« Reply #103 on: April 22, 2022, 03:55:13 PM »
Re: SuperSlideStyle
« Reply #104 on: April 23, 2022, 09:36:03 AM »
For some reason those pictures are not showing.
