Author Topic: InsideOut104's White 2010 SE 4x4 in San Diego NEW LIFT AND WHEELS AND TIRES  (Read 20923 times)
s14slide
  • 4wd Pts: 9
Re: InsideOut104's White 2010 SE 4x4 in San Diego
« Reply #15 on: November 20, 2012, 07:25:28 PM »
There's only one thing wrong with this pic............it's a second gen.
j/k bro, that is a great pic.  I like it.
Then again, a first gen would look just that much better.
"Sometimes paranoia is just having all the facts."
     - William S. Burroughs
InsideOut104
New wheels and tires! Black ProComp 7089 with 265/75/16 Cooper Discoverer S/T Maxx!
http://i953.photobucket.com/albums/ae20/cphillips6480/2010%20Nissan%20Xterra%20SE%204X4/IMAG0541_zpsaa8dbdad.jpg
http://i953.photobucket.com/albums/ae20/cphillips6480/2010%20Nissan%20Xterra%20SE%204X4/IMAG0543_zps684f570c.jpg
http://i953.photobucket.com/albums/ae20/cphillips6480/2010%20Nissan%20Xterra%20SE%204X4/IMAG0544_zpsf9d96792.jpg
InsideOut104
I'm getting some rub issues. I did the melt mod and I am still getting rubbing on the very tip of the corner of the rear of the front fender liners. I need to just get rid of the fender liners!
Anyone have any ideas?
I had the same rubbing, when I lifted mine, and installed 285/70/17's. I melted modded the crap out of the fender, but it still rubbed in the same spot yours does. I ended up using an razor, at the last Cleghorn run, to cut away the rear corner of the front fender. I cut, just the area that was rubbing, and WHA LAH.
You don't want to lose the fender liners. They prevent a ton of road noise and other stuff.
InsideOut104
Yeah I took a razor blade and cut the plastic fender liner in the corner. Still getting rubbing. I'm gonna need to shave away some metal I think. I didn't even step up to 285's! It's the damn ProComp wheels causing it I think!
You are right the offset of the Procomps I believe is appr.  1 1/2 inches outset which is causing you're rubbing.   With my Procomps and a 2 1/2 inch lift, I still had to "trim" the inner lip of the fender to get it to clear.
« Last Edit: January 08, 2013, 09:17:24 AM by SoCalXTerry »
InsideOut104
I think I will need to trim a little sheet metal. If I go off roading, I will probably get even more rubbing the way it sits now. I also think I am going to raise the front Radflo's about a 1/4 inch. I lowered them quite a bit from where they were set down to the factory "rake".
Don't know if its a misprint or not but 3000 lb recovery straps are junk, step up to a 20,000 lb minimum.  Otherwise nice rig.
Lava
  • 4wd Pts: 21
Like the new Rubber. How is the road noise with the Coppers?
My other vehicle is an X-WING
Justin - KK6JEC
InsideOut104
What road noise? :)
InsideOut104
UPDATE!!
Got rid of the ProComp 7089's and picked up some 16x8.5 Level 8 Guardians. No more rubbing! :)
Also, this past weekend I painted the upper front grille flat black. I think it turned out really nice!
I'll paint the lower portion and rear bumper next time I have a chance as well!
http://i953.photobucket.com/albums/ae20/cphillips6480/2010%20Nissan%20Xterra%20SE%204X4/IMAG0816_zpsec170fb3.jpg
http://i953.photobucket.com/albums/ae20/cphillips6480/2010%20Nissan%20Xterra%20SE%204X4/IMAG0817_zpsbd6a0842.jpg
Looking Mean and Clean... time to get it dirty again :)
InsideOut104
Trust me, I know I need to get out and get it dirty! I'm just sooooo busy! Ahhhhhhhh!!!
