Author Topic: What have you done for your Rig lately.  (Read 565063 times)
Alex
« Reply #1020 on: February 22, 2016, 05:54:07 PM »
A few other easy mods that come to mind: remove the rear sway bar, remove rear mud flaps, and if you're already running bigger tires on the 2nd Gens, look up how to do the melt mod for inside the front fenders. And y'all should make a page in the Display Case to show some pics as things progress! :)
« Last Edit: February 22, 2016, 05:55:47 PM by Alex »
RattFink27
    • 2007 Xterra S
« Reply #1021 on: February 23, 2016, 08:28:29 PM »
This weekend I installed the OME suspension kit and a couple days before that I installed the OEM fog lights. And a month before that was some duratrac tires and new wheels. Next up is rock sliders and under garment protection.  ;)
« Reply #1022 on: February 23, 2016, 09:14:19 PM »
So today I modified my trans mount again to help deal with a problem there. And also added few inches of metal to the panhard bracket to get everything leveled out. I'll post pics tomorrow. I should be to test drive it tomorrow also
Sent from my SM-N915V using Tapatalk
Riz98
  • 4wd Pts: 8
  • PBR ASAP
    • 2002 Nissan Xterra
« Reply #1023 on: February 24, 2016, 11:13:36 AM »
Changed the transmission fluid, transfer care, and rear differential fluid.  I was going to do the front but the diff cover doesnt have a drain plug so I wasnt prepared to pull the cover off and reseal it.  The fill plug also requires a large allen key that I dont have so I may get to that this Friday.  The transmission fluid didn't look too bad.  Had a slight tinge of brown to it but was mostly red still.  The transfer case was pretty dirty and had a large amount of metal shaving on the drain plug.  No big chunks so for now I'm good.  The rear diff had some white milky fluid in it which I am assuming was water but once that drained out it had a nice purple color to it.  AFT synthetic for the transmission, Master Pro Synthetic 75-90 for the transfer case, and Master Pro 80-90 for the diff's.  I'll probably change out the diff fluid every 30,000 miles or after deep water crossing so I didn't bother using a synthetic.
PainRoller
  • 4wd Pts: 46
  • DILLIGAF
« Reply #1024 on: February 27, 2016, 02:39:57 PM »
Have you considered doing the Breather Extension MOD on your rear diff?  Will def help keep water out during water crossings.....
« Reply #1025 on: February 28, 2016, 07:34:29 PM »
Finally got around to installing the new LED bumper lights I got for Christmas with a little help from the current driver.
« Reply #1026 on: February 28, 2016, 08:35:52 PM »
The front dif does have a drain plug, iirc its on the driver's side, fill plug is on the passenger side.  The drain and fill use a 10mm Allen
Riz98
  • 4wd Pts: 8
  • PBR ASAP
« Reply #1027 on: February 29, 2016, 12:31:09 AM »
Dana 44 front axle to be specific.  Anyways I pulled the bolts off the front diff cover and that thing is on there good.  Tried for a little while to get the cover free from the sealant but it wouldn't budge.  The fluid is right at the fill plug so I left it for now.  I think a new cover might be a future mod so I can just fill and drain and be done with it.  Also purchased some wheels spacers from Amazon to widen the front axle to match the rear.
« Reply #1028 on: February 29, 2016, 12:46:53 AM »
  What did they seal that cover with JB Weld?
Riz98
  • 4wd Pts: 8
  • PBR ASAP
« Reply #1029 on: March 01, 2016, 12:35:57 AM »
Yeah maybe.  It looks like black RTV was used and probably alot of it.  Any good tips on getting the cover off the next time I do this?  I didn't want to pry it off and mess up the mating surface of the axle.  Probably try this again soon with a six pack of some good IPA's for help.
« Reply #1030 on: March 01, 2016, 12:56:17 AM »
I'm not exactly sure what would be the easiest way to go about doing it if you are worried about marring the metal. Gently tapping a straight slot screw driver straight in with a rubber mallet has always worked well for me. Make sure the screwdriver is more over towards the diff cover so the lions share of the existing RTV is still on the diff and keep the angle straight. If something does get scratched up in the process I'd rather it be the cover. If you have a stock cover now might be a good time to upgrade to something more solid? In the end as long as it gets sealed properly some minor scratches on the cover shouldn't be too much of an issue.
Riz98
  • 4wd Pts: 8
  • PBR ASAP
« Reply #1031 on: March 01, 2016, 11:04:16 AM »
Yeah I will try and use a screw driver and mallet like you suggested.  I'll probably hang onto the current diff cover as a quick search shows that it is well built and thick.  http://www.wideopendesign.com/Product/149/CRANE-Dana-44-Diff-Cover.aspx    It would be nice though to have a drain plug.
« Reply #1032 on: March 01, 2016, 12:28:21 PM »
putty knife and a mallet.  work around the flange with the putty knife, much better than a screw driver and less likely to gouge the flange.
« Reply #1033 on: March 02, 2016, 12:42:42 AM »
Ouch, that's one expensive diff cover ($299)..... If you need a drain plug as long as you are careful you can always drill your own hole into it then tap it and you will be good to go. It's not too hard just take your time and make sure you get it drilled in the spot you want it. I have drain plugs but don't mind pulling the cover off either as it's a good way to take a look at the gears for developing carnage.
« Reply #1034 on: March 02, 2016, 02:34:23 PM »
Like Jordan said....
   You can also add insurance by using plastic putty knives like these
www.amazon.com/dp/B0027BBHGG/ref=cm_sw_r_awd_-T21wb9Y2CC1N
   Wedge it in there then go to town with a mallet or hammer.
« Last Edit: March 02, 2016, 02:42:09 PM by Toro »
