Author Topic: What have you done for your Rig lately.  (Read 691508 times)
Re: What have you done to your Rig lately.
« Reply #105 on: April 08, 2013, 05:49:38 PM »
I'll have to figure something out. With a dual receive ham and a cb, I think I'd rather have separate speakers.
The volume's work from the radios them selves. You can have each as soft or as loud as you want. I can immediately tell the difference between the two from the sound quality.
« Reply #106 on: April 08, 2013, 05:53:08 PM »
Where did you get the speaker, and what brand is it?
http://amzn.com/B000ZIC18Q
« Reply #107 on: April 08, 2013, 07:58:12 PM »
Ordered...Thanks Toro
« Reply #108 on: April 13, 2013, 04:31:50 PM »
Installed a new CB Speaker. Fits like a glove. Inspiration courtesy of Toro.
http://i249.photobucket.com/albums/gg237/kaveh34/5F6188D4-4686-428E-8C34-A805F8C6370F-1400-0000015F01A94C1D_zpsb87e6ee2.jpg
« Reply #109 on: April 29, 2013, 09:39:15 PM »
Adjusted my Radlos to reduce my rake since the AAL's and Shackles.
Loosen the lock nut
http://i249.photobucket.com/albums/gg237/kaveh34/B5C2EA3C-7635-47FC-8F73-51C5D3A1EEBE-11335-00000DC2F17B63E0_zps2b5620b9.jpg
Gently convince the adjustment nut to CRANK UP. Not easy, even with two people.
http://i249.photobucket.com/albums/gg237/kaveh34/C18EA7E5-1DC4-4C21-B9CD-67F418D69EB6-11335-00000DC2E1F4A99B_zpsdfc842eb.jpg
Rake adjusted. It's not level, but our rigs are designed to have a little rake.
http://i249.photobucket.com/albums/gg237/kaveh34/797C03F0-139D-4B49-9E28-F79B39E78E9E-11335-00000DC387453415_zps62519784.jpg
Thanks for the help Drshankles
« Last Edit: April 29, 2013, 09:40:58 PM by HEVAK »
« Reply #110 on: May 03, 2013, 09:55:52 AM »
Sweet rides!  I an finally leavin Austin, TX and heading home to install my Fox shocks and get the air conditioner fixed. .
« Reply #111 on: May 03, 2013, 11:20:18 AM »
New 5" LED Spot Lights. I'll wire em this weekend  ;D
http://i249.photobucket.com/albums/gg237/kaveh34/CE5C1A10-E80B-4FBB-BF03-F8676CDC7023-14893-00001185E8DFB584_zps0618daa1.jpg
« Reply #112 on: June 01, 2013, 10:08:42 PM »
Gott the air conditioner fixed on my X, installed Nology Hot Wires which increase the ignition wires spark from 15k to 45k Volts,  got an oil cooler thermostat installed in-line, and added black shock boots to my Fox 2.0 shocks.
« Reply #113 on: June 12, 2013, 09:28:35 PM »
Had a small oil leak on the oil cooler thermostat hoses.  got those changed and added 1/2" NPT male to -8AN fittings, and -8AN female to hose barb to make the oil cooler and thermnstat more serviceable and easily removable.
Had to leave to AZ for a few days.r
« Reply #114 on: June 16, 2013, 09:02:14 PM »
I should be running a damn chop-shop!
Pulled my coil-overs out in 18 min flat!
Now, off to get re-sprung.
« Reply #115 on: June 17, 2013, 09:20:15 AM »
That has to be some kind of record.   Averaging 9 mins per side?  :o
BTW who is doing the re-springing for you?
« Last Edit: June 17, 2013, 09:23:57 AM by SoCalXTerry »
« Reply #116 on: June 17, 2013, 09:23:53 AM »
Added 2 cheap $15 lights to front bumper. good cheap project to work on wiring knowledge.
http://i112.photobucket.com/albums/n193/marinecorpwife8/Santiago%20Peak%206-15-13/15.jpg
« Reply #117 on: June 17, 2013, 10:09:08 AM »
A local shop. Should be a quick spring swap.
« Reply #118 on: June 17, 2013, 11:27:41 AM »
So what are you saying we are going to need a good set of spring compressors in our repertoire  :D   My problem is I've always considered that kind of a "Death defying" act.   Actually I wish I had had them at Superstition Mtn.  when I was trying to put that coilover back together.
« Reply #119 on: June 17, 2013, 12:04:17 PM »
Spring compressors spook me, but as much as I'm paying to have someone do them, I should just go out and get one my self.
