Author Topic: What have you done for your Rig lately.  (Read 565200 times)
« Reply #1065 on: March 23, 2016, 10:31:34 PM »
finally installed my PX4 front coil struts on my X. Just waiting on the rear shocks and I will installed the rear leaf pack & shocks.
« Reply #1066 on: March 24, 2016, 12:57:21 PM »
Removed my mud-guards last night, and managed to not break any of the push clips! :)
« Reply #1067 on: March 26, 2016, 03:45:04 PM »
Finally had the AFE Hi-tuck from my Frontier modified to fit the Xterra, just a few cuts and slight re-bends. It certainly wasn't a direct fit like AFE said it would be. Oh well, it works now.
« Reply #1068 on: March 26, 2016, 05:07:23 PM »
Does the tire hit the diff?
« Reply #1069 on: March 26, 2016, 05:17:06 PM »
You know, I haven't even paid attention to that until now. I'll have to look.
« Reply #1070 on: March 26, 2016, 05:22:49 PM »
you might have to 'notch' the spare tire >:D
« Reply #1071 on: March 29, 2016, 09:07:30 AM »
Dropped the front skids to change the front diff and engine oil.
   Wife is out getting new bolts for them. Rear diff oil getting changed tonight and all will be buttoned up for Moab this weekend.
« Reply #1072 on: March 29, 2016, 01:56:37 PM »
....for Moab this weekend.
Have fun man, I'll be thinking of ya.
« Reply #1073 on: March 29, 2016, 03:22:02 PM »
Every time I read Moab, it makes me think of this video
« Last Edit: March 30, 2016, 07:06:02 AM by GeoYota »
« Reply #1074 on: March 30, 2016, 07:09:57 AM »
Great video Steve...and I raise you...
« Reply #1075 on: March 31, 2016, 10:03:16 AM »
Making electricity flow in the dodge. Working on setting up a 600w audio battery in the back with an isolator so I can power accessories and LEDs in the back.
« Reply #1076 on: March 31, 2016, 10:08:38 AM »
very nice, I still need to learn how to make badass power rigs like that.
Riz98
  • 4wd Pts: 8
  • PBR ASAP
    • 2002 Nissan Xterra
« Reply #1077 on: March 31, 2016, 07:16:33 PM »
I installed "The Cure" from Ruff Stuff today on my drag link to try and limit the tie rod from rolling around.  So far I only drove to work but it feels pretty similar to what I had without it.  Tomorrow I'll be replacing the worn out rod ends on my track bar with some nice FK rod ends.
fourxfunk
« Reply #1078 on: April 01, 2016, 11:19:31 PM »
I had the day off! Tried taking off my factory rear shocks to replace with 0-2" 5100's.. PB blasted 'em and tried some more. Then I said, "heck it,  I'm going to Harbor Freight". I bought their biggest 1/2" breaker bar and some sockets and 45 minutes later, I was done.
After a trip to Portillo's for a Maxwell Street polish,  onion rings and a large diet coke (don't laugh,  I've got a figure to maintain) I waddled to the mailbox to find these goodies.. Thanks Geoyota!
I must say it was a good day.
« Last Edit: April 01, 2016, 11:22:45 PM by fourxfunk »
Riz98
  • 4wd Pts: 8
  • PBR ASAP
« Reply #1079 on: April 02, 2016, 09:48:55 AM »
Here are the pictures from when I did "The Cure" from Ruff Stuff and the new track bar rod ends.
Drag link removed from tie rod
http://i1305.photobucket.com/albums/s541/Riz98/IMG_2908_zps9thciugf.jpg
 The Cure, more or less a hardened plastic bushing to prevent the drag link and tie rod from rolling, installed.
http://i1305.photobucket.com/albums/s541/Riz98/IMG_2911_zpspbc4xian.jpg
Track bar bolt is too close to the drag link to gain access to
http://i1305.photobucket.com/albums/s541/Riz98/IMG_2912_zpsqpdvldgq.jpg
Removed the passenger side tie rod from the knucle.  A lot of room now
http://i1305.photobucket.com/albums/s541/Riz98/IMG_2914_zpsvtn6bsaa.jpg
Old rod end VS new rod end.  With the old rod end I was able to feel the movement on the bearing with my hands.  Imagine what the weight of the truck was doing to it.  This was the cause of my slight vibration around 55-65 mph on the highway.
http://i1305.photobucket.com/albums/s541/Riz98/IMG_2916_zpsmiq7dkie.jpg
Chevy 1 Ton steering kit from Ballistics Fabrication.  Parts Mike is also a good source for steering upgrades and will cut and assemble the linkage but you have to give the measurements.
http://i1305.photobucket.com/albums/s541/Riz98/IMG_2917_zpsmimfkkpu.jpg
One end of the track bar had a small edge of metal from when the track bar was cut.
http://i1305.photobucket.com/albums/s541/Riz98/IMG_2918_zpskxomvpwf.jpg
A couple minutes with a hand file and the track bar was looking good.  Wanted to make a nice flat seating area for the lock nut.
http://i1305.photobucket.com/albums/s541/Riz98/IMG_2920_zps8a4dnku2.jpg
Anit-Seize for the next time I make an adjustment or replacement.
http://i1305.photobucket.com/albums/s541/Riz98/IMG_2921_zpshtff7lnj.jpg
Track bar bolt going back in with Red Lock tight.  Torqued to 150 ft lbs.
http://i1305.photobucket.com/albums/s541/Riz98/IMG_2922_zpseenspjaj.jpg
The reassembly went smoothly and the initial drive was a big difference.  I would strongly suggest anyone using the Calmini SAS kit that has some vibrations to check the track bar rod ends if they are the original ones from the complany.  I used FK rod ends part number JMX12T.  Both sides are right hand threaded.  Summit Racing has them for a good price and shipped to my door in 2 days.
