Author Topic: What have you done for your Rig lately.  (Read 565197 times)
« Reply #1080 on: April 02, 2016, 04:56:02 PM »
Like a glove...
fourxfunk
« Reply #1081 on: April 02, 2016, 05:28:34 PM »
^Now that's sweet!^
« Reply #1082 on: April 02, 2016, 07:17:45 PM »
Nice Tetris Job
« Reply #1083 on: April 02, 2016, 08:30:52 PM »
loving it, mind to ask what specific tools you got so i can copy? :)
« Reply #1084 on: April 02, 2016, 10:06:47 PM »
Nice Tetris Job
Yeah, it definitely took me a few minutes to figure out the best fit.
48" hi-lift and just about any axe and short handle shovel should fit. I had to remove the stock jack so the shovel would sit low enough for the seats to lock.
« Reply #1085 on: April 03, 2016, 04:07:07 PM »
I always love the simple solutions 8)
Alex
« Reply #1086 on: April 03, 2016, 07:33:18 PM »
I'd want to get a 2nd Gen just to do that, very nice! :D
« Reply #1087 on: April 03, 2016, 07:41:13 PM »
You already have yours nicely mounted.
« Reply #1088 on: April 03, 2016, 08:25:01 PM »
Your Rig is Yellow, I wish I could have gotten a 2nd Gen in Yeller  >:D
Riz98
  • 4wd Pts: 8
  • PBR ASAP
    • 2002 Nissan Xterra
« Reply #1089 on: April 08, 2016, 09:07:26 PM »
Replaced the upper shackle bolts on both sides.  The left side was broken and I am glad I noticed it.  Also replaced the transfer case output seal.  So far nothing is leaking.  The transfer case was leaking right on the exhaust so that made for a pretty nasty smell when stopped at a light.
ghenderson21
    • 2012 Super Black S
« Reply #1090 on: April 09, 2016, 07:50:12 AM »
Finally tackled the oil change, and the oil filter SUCKS to get to. lol. Now that it's done, next time will be easier. Made the switch to full synthetic.
Bought a hi-lift and put it under the seats, as well as some small toolboxes. Moved the stock jack into the lock box up top.
Next, onto the diffs, transfer case, and transmission fluid changes.
« Reply #1091 on: April 09, 2016, 10:28:48 AM »
Cover all the joints and worm gear in grease then wrap it in plastic wrap. The elements will render it worthless if you ever need it.
« Reply #1092 on: April 09, 2016, 05:29:55 PM »
Very nice Rik! I still need to get that shovel!
Today I picked up a receiver hitch shackle/d-ring and a recovery strap. My first off-road supply purchase! They are tucked away nicely in a backpack in the false door in the cargo area.
« Reply #1093 on: April 09, 2016, 10:16:04 PM »
Well, I did this today and it took way too long. I also got the alignment redone to get rid of the positive camber that I had them leave in so the UCAs would clear the CBs. I'll be trimming them tomorrow.
« Reply #1094 on: April 10, 2016, 10:42:58 AM »
 The "JF" mod.
