Author Topic: What have you done for your Rig lately.  (Read 715140 times)
SD_Frontier
Re: What have you done to your Rig lately.
« Reply #165 on: July 02, 2013, 09:31:09 PM »
4x4parts.com for a C200
That's right. Thanks for helping me remember.
Code Name: SHAMU
Build Thread
SocalTerraX
    • 2007 Xterra
« Reply #166 on: July 03, 2013, 07:20:34 AM »
Well, if I remember correctly, you're like 12teen, so I'd leave the beer purchasing to us old folks....  ;)
Lmao.
Looks good Adio. Now just for some big boy tires too.
Adio.
  • 4wd Pts: 10
« Reply #167 on: July 03, 2013, 10:51:45 AM »
Do I look like I'm made of money?  ;D
Ahaha I'll throw on new tires eventually, today I'm making a shovel and axe mount for my roof rack.
« Reply #168 on: July 03, 2013, 03:36:38 PM »
This is what I came up with.
Odinson
  • 2009 Xterra 4x4
« Reply #169 on: July 03, 2013, 04:28:05 PM »
What is that lower piece called, Toro? That you fit the QuickFists to - I couldn't find it at HomeDepot and ended up just using pipe hangers (still worked but only holds 1 clamp)
Re: Re: What have you done to your Rig lately.
« Reply #170 on: July 03, 2013, 04:42:10 PM »
Looks like an exhaust clamp
Not sent with the stupid auto guide app
« Reply #171 on: July 03, 2013, 06:15:09 PM »
It's an exhaust clamp welded to a piece of 1" flat stock.
Adio.
  • 4wd Pts: 10
« Reply #172 on: July 03, 2013, 08:31:25 PM »
I'm doing something slightly different than that, whenever I get sliders and then a hi-lift I'll probably just do that. But I'm using Pipe repair clamps, and then drilling 2 holes in the shovel and axe and mounting one ontop of the other. I'll have it done tomorrow, I just need to get the right size clamps.
Love your idea though! I saw your thread on thenewx on it.
« Reply #173 on: July 04, 2013, 08:56:06 AM »
It's okay, I got this.
Elevated levels of awesomeness.
Adio.
  • 4wd Pts: 10
« Reply #174 on: July 04, 2013, 12:55:25 PM »
Axe and Shovel Mounts!!!
I need to saw the bolts down, but it's a really nice and sturdy mount.
« Last Edit: July 04, 2013, 01:16:32 PM by Adio. »
LupinOne
  • 4wd Pts: 13
« Reply #175 on: July 05, 2013, 10:11:09 PM »
Rotate that shovel 180 degrees and the blade will contour your vehicle and not stick out whacking things or making drag. :)
John "LupinOne"
KF6BRF
Adio.
  • 4wd Pts: 10
« Reply #176 on: July 05, 2013, 10:19:55 PM »
You see since I don't have any armor weighing me down and there's an eagle on the rear of my car... The chances of my X picking up and flying are pretty high, so the drag from that shovel is a must.
No just kidding haha good suggestion.  ;D
I'll fix that tomorrow, I had to buy a new shovel and more clamps to re-mount it today. The shovel as seen in the picture you quoted is broken because that kind of material isn't meant to be drilled into... Now I decided to put clamps around the new shovel without having to drill into it, and I re-mounted it to the position seen in the picture. I'll take pictures of it tomorrow.
« Reply #177 on: July 05, 2013, 10:22:05 PM »
i was wondering if drilling holes in the handles would weaken them, guess thats my answer haha.
Adio.
  • 4wd Pts: 10
« Reply #178 on: July 05, 2013, 10:25:42 PM »
Yeah I noticed a crack towards the bottom of the shovel and I pulled it off and put some pressure on and it started cracking even more... I'm not sure what I was thinking drilling holes into that kind of material. The axe is fine though.
« Reply #179 on: July 05, 2013, 10:27:41 PM »
Try chopping wood with it
