Author Topic: What have you done for your Rig lately.  (Read 564373 times)
« Reply #1680 on: July 22, 2018, 12:28:16 PM »
Since your south of the border, shouldn't they be bright green? :D
hahahaahahahahahahahhahahahahahahahahaah
« Reply #1681 on: July 22, 2018, 01:37:00 PM »
My ARB RTT has arrived. Cant open until brackets are made. Lucky me, I have a buddy who is a fabricator and will be cutting proper length brackets. Will open it and snap a pic for the gram hopefully by Wednesday. It does have that semi nasty storage mildewy smell on it. Will leave it overnight opened and lay baking soda and  ozone odor eliminator spray.  Will wash the mattress cover and get it "homely". Til then, I cant wait to get it out in the wild where it belongs. :)
Best part, I got it dirt cheap.
37646434_10211135616977764_2802439604857208832_n" border="0
« Reply #1682 on: July 22, 2018, 02:30:00 PM »
are those in case you flip over? so the search party can see you from the air?
No kidding.  That's kind of what I said when my wife asked why I was painting the skids on my 2005 black Xterra yellow.  It's a safety feature.
« Reply #1683 on: July 22, 2018, 07:19:53 PM »
Some tswap / axle swap with a little help from my friends.
https://imagizer.imageshack.com/v2/1024x768q90/922/V8yBmN.jpg
(and yes, we are going drop the rack down.  I just had to see it mounted stock before we cut it up!_
FBinSD
  • 4wd Pts: 17
« Reply #1684 on: July 22, 2018, 07:27:30 PM »
Nice! Even cleaned the rig for the photo!  Looks great.
2012 Frontier pro4x
« Reply #1685 on: July 22, 2018, 07:39:26 PM »
Thanks Frank!  I'll give you a pass for not showing up to help :)
Here are some more photos
https://imagizer.imageshack.com/v2/1024x768q90/922/iWqboe.jpg
https://imagizer.imageshack.com/v2/1024x768q90/921/Fv0g3q.jpg
https://imagizer.imageshack.com/v2/1024x768q90/921/KCXDI4.jpg
« Reply #1686 on: July 22, 2018, 09:00:37 PM »
Steve at it again with the killer shots... Rack look dope AF.
btw Thanks for the invite   :(
« Reply #1687 on: July 22, 2018, 09:41:14 PM »
Looks awesome Steve ,  >:D
your always 3 steps ahead of me
« Reply #1688 on: July 23, 2018, 02:03:46 PM »
Public service announcement: Don't use anything other than stainless hardware in the factory roof rivnuts/nutserts. When I installed my aluminum rack (that is still for sale, by the way :) ), I thought the shiny silver stainless stuff looked bad against the cool black powdercoated rack. So I purchased black zinc oxide hardware instead. Well, fast forward a couple of years when I go to pull that rack off and replace it with my new front runner rack, and nearly every single bolt had rusted up inside the threaded inserts (rivnuts) on the roof. Nearly all of the ruvnuts ended up breaking free, spinning loose in the roof instead of allowing the bolts to back out of them.
What a PITA. I removed the headliner and was able to clamp vice grips onto the back of most of them in order to finish backing the bolts out. Some of them are blocked by structural supports, and required force to remove the entire rivnut from the roof (which leaves an awful mushroom shaped hole. :( ). Anyway, I spent all day yesterday drilling them all out and installing new ones that I ordered online. Sealed the holes up with silicone as I installed them to prevent any leaks. And yes, I know my roof is extremely dirty. I'll be washing it before the new rack gets installed.
The culprits:
Headliner removed:
New rivnut installed. So beautiful:
Here's the combination of parts I used to install them, in place of a proper tool. Worked well, but I went through about 3 or 4 of those star washers:
The installation process. My hand and arm are super sore from the amount force required on that ratchet. I didn't want to use something mechanical though, for fear of over-tightening them:
A dab of clear silicone around each hole before installing the new nuts. This was especially important, as the metal was pretty messed up around a few of them from removing them:
"Saudi Spec," as knight rider would say. I wonder how much better my gas mileage is now.
« Reply #1689 on: July 23, 2018, 02:38:47 PM »
Ugh. When we did painroller’s one of the nut insert spun. It was a pain for one, can’t imagine dealing with all of them.
« Reply #1690 on: July 23, 2018, 07:35:41 PM »
The gas mileage is negligible but the noise reduction is yuge.
« Reply #1691 on: July 23, 2018, 07:47:29 PM »
Joe, that looks miserable.
Glad you got it sorted.
« Reply #1692 on: August 18, 2018, 02:21:41 PM »
Roof rack project is finally complete. New rack has received the "Toro mod," and looks great on the rig! I purchased the Rough Country "X5" series light bar, which turned out to be a beast! It BARELY fits in the space between the front of the rack and the roof.
https://i.imgur.com/bEmiyht.jpg
https://i.imgur.com/bIOkYFF.jpg
https://i.imgur.com/ZobUAc7.jpg
https://i.imgur.com/1Gxdm4Z.jpg
https://i.imgur.com/60PX4go.jpg
https://i.imgur.com/KJqEi0h.jpg
https://i.imgur.com/N6BGL7e.jpg
« Reply #1693 on: August 18, 2018, 08:05:45 PM »
looks awesome
Riz98
  • 4wd Pts: 8
  • PBR ASAP
    • 2002 Nissan Xterra
« Reply #1694 on: August 24, 2018, 11:43:42 PM »
New tires and wheels showed up today.  This time around I will be using wheel locks to hopefully keep some of the less intelligent thieves away.  Short story a week ago today all four of my tires were stolen and I walked out Saturday morning to my Xterra sitting on the rotors and drums.  Went with some Falken Wildpeak MT's 35x12.5x15 with some black steel wheels.  While the X was just sitting for the week figure why not look at the brakes.  Front driver caliper was sticking which was probably causing my slight pull to the left.  Ended up replacing both front calipers and brake pads.  Rotors have alot of meat left on them and dont show any signs of being damaged so those will not get replaced.
