Author Topic: What have you done for your Rig lately.  (Read 563560 times)
« Reply #660 on: March 06, 2015, 09:38:16 AM »
Lowrance are primarily marine GPS units but they are great off road GPS units as well.
LupinOne
  • 4wd Pts: 13
« Reply #661 on: March 06, 2015, 03:08:38 PM »
Is the 300 rebate, on top of that price?
It was $846.37 - $300(rebate) = $546.37 net.
The 300 rebate will be a prepaid visa card they will send you.
John "LupinOne"
KF6BRF
« Reply #662 on: March 06, 2015, 04:02:56 PM »
Cool.
....still can't afford it
« Reply #663 on: March 11, 2015, 10:00:56 PM »
Well I did plugs and coils in the ole' X today.  DAMN What in PITA.   Because of fat hands and one stinking bolt, I had to remove the Intake Manifold Collector.   Once again DAMN.
The big problem is that my rig is so tall that I needed a step stool to get to it..   Right.  Back and forth, back and forth.    I'm tired.
P.S.  I changed my mind after starting and bought new coils also which came with plug wires fully assembled.   I had bought wires with the plugs and now don't need them.   So I would be willing to make a great deal for anybody that needs them.
« Reply #664 on: March 11, 2015, 11:39:28 PM »
why did you replace the coils? were you having issues? also, what wires? the x is coil on plug so there are no wires. did you buy a first gen x?
« Reply #665 on: March 12, 2015, 06:12:20 AM »
Well Jordan the whole coil/wire assembly is three pieces.   The coil, the rubber wire housing and the wire that runs down the inside. I figured while I was in there I might as well replace the coil preemptively also.   Glad I did, cause I don't want to go back in there for that X's lifetime.
« Reply #666 on: April 03, 2015, 07:14:27 PM »
All Pro 1.5" wheels spacers installed...a little clearance for the 265/75's.  ;D
« Reply #667 on: April 03, 2015, 11:33:41 PM »
you, of all people, should know what's missing here.....
« Reply #668 on: April 04, 2015, 12:10:06 AM »
Duh...my bad.
http://tapatalk.imageshack.com/v2/15/04/04/78804f9a826f160b39fe2f9eea744912.jpg
http://tapatalk.imageshack.com/v2/15/04/04/4bf725837e12044c8c25275be623ee0c.jpg
http://tapatalk.imageshack.com/v2/15/04/04/9a1f274804fd4d27bdbe5745e6bf8379.jpg
Sent from Planet Claire
 using Tapatalk
« Reply #669 on: April 04, 2015, 07:35:40 AM »
I bet those are torqued to spec.
« Reply #670 on: April 04, 2015, 08:03:40 AM »
90 lbs.
 using Tapatalk
Re: Re: What have you done for your Rig lately.
« Reply #671 on: April 04, 2015, 08:19:00 AM »
90 lbs.
 using Tapatalk
You make me sick.....
« Reply #672 on: April 04, 2015, 05:43:34 PM »
Tight spec
« Reply #673 on: April 04, 2015, 07:04:44 PM »
Did the 60K service.
Fluids changed to amsoil stuff + unicorn tears for the transmission.
Diffs
Tcase
Transmission
Engine
Radiator
Checked belts, hoses, power steering etc.
Everything looked pretty good. I did the same thing at 30k so I might of been able to wait a little longer.
Thanks knightrider for the help and space to work.  Sorry about my transmission causing a murder scene on your driveway.
Some pics from the day.
Jordan was drooling over this Defender
http://imagizer.imageshack.us/v2/800x600q90/913/hs9lyR.jpg
Hurray for powertools!
http://imagizer.imageshack.us/v2/800x600q90/911/DRnbuV.jpg
Wouldn't be wrenching without a busted knuckle, literally.
http://imagizer.imageshack.us/v2/800x600q90/540/kIcNkq.jpg
« Reply #674 on: April 04, 2015, 07:10:15 PM »
Diffs
Tcase
Transmission
Engine
Radiator
Nice~!
Tight spec
85-90 lbs. per the All Pro instructions...and re-torque every 10 miles until no tightening is necessary.  I've seen these sheared off (although they were not hub centric spacers) and it wasn't pretty...or an easy fix.
