Author Topic: Attenna Mount  (Read 5072 times)
Attenna Mount
« on: September 30, 2012, 04:20:33 PM »
I want to mount my attenna on my rear hatch or rear window. Can you guys suggest a particular mount and ideal install location??
Thank you
Re: Attenna Mount
« Reply #1 on: September 30, 2012, 05:56:44 PM »
Thank you
Check this out Ray:
Walcott CB Trunk/Hatch Antenna Mount
Lava
  • 4wd Pts: 21
Re: Attenna Mount
« Reply #2 on: September 30, 2012, 08:41:02 PM »
Ray,
I have this very mount on my rig. I like it, but I had some grounding problems. Make sure you use a Dremel or small tool to clear some of that paint on the underside of the hatch. The mount attaches by using 4 small allen head set screws.
You can kind of see it on my CB install that I posted @ http://www.sccxterra.com/smf/index.php/topic,1498.0.html   (SEE PAGE 2)
It seems strong enough, but I may add a spring to the base to assist in tree Branch deflection since 4' is a little tall from my mount spot. Your antenna should be okay.
I can swing down to the HRO in Kearney Mesa and grab one for you if you want to meet up this week? They were the cheapest I found for that mount. I'm off THU/FRI/SAT. Just PM Me
Lava (Thats kinda Catchy isn't it?)  ;D
My other vehicle is an X-WING
Justin - KK6JEC
Re: Attenna Mount
« Reply #3 on: September 30, 2012, 08:53:25 PM »
Thanks guys!!
Yeah, LAVA is a good one. I think you should run with it.
Lava
  • 4wd Pts: 21
Re: Attenna Mount
« Reply #4 on: September 30, 2012, 08:54:58 PM »
I just tried to order LAVAROX for plates, but someone's got em already!  >:(
Justin - KK6JEC
