Author Topic: MOD DAY OF DOOM! - January 31, 2009  (Read 73341 times)
Soylent Yellow
  • 4wd Pts: 5254
Re: MOD DAY OF DOOM! - January 31, 2009
« Reply #45 on: January 27, 2009, 06:17:39 PM »
Most definitely!
I'm putting off my diff drop for now.  Let me know if you're coming so I can start sending out my address.
 I got the address but it looks wierd with the hyphen is this correct?
It correct.  That's the way they do it out here in the boonies.  Use a comma if it works better.  Anyone else need the address?
« Reply #46 on: January 27, 2009, 07:41:10 PM »
I didn't have time to get the bolts I need to fix my CV... argh. the hardware place close so early!!!
I might be out.  I got to get the part saturday so I can make it to pismo.
Sorry guys.
What bolts do you need. If I can help I will just to have your experince there...
« Reply #47 on: January 27, 2009, 07:45:23 PM »
Bummer...
My inspiration is gone...  :'(
My dreams are shattered...  :-\
My Otterpops are melted...  :-[
If the diff gasket comes we will do it. ;)
Read my post as I have attached instruction for the drop. No gasket needed. But there is one hitch. We need a sawza or some gasoline to burn out the old bushing and then pry out the old metal shim. Another another reason I want Spencer to go since he has done this. You remove the cv on the inside , like I did in your driveway but the inside and then remove the front of the diff and then crossmember. Looks easy enough but the shim part.
« Reply #48 on: January 27, 2009, 07:48:20 PM »
Sorry guys.
heck I can even give you a CV
  • 4wd Pts: 17
« Reply #49 on: January 27, 2009, 11:21:28 PM »
Quick question: Is it ok to do a diff drop on a stock torsion-bar-cranked front suspension? With future UCA upgrade in mind?
« Reply #50 on: January 27, 2009, 11:34:40 PM »
I will see what I can do.  I will try to see if Ace carry what I need. If not,  I will try to skip lunch and go to mcfadden dale for some.
I actually never did the diff drop, but it can't be that hard.  you don't need gas, all you need is a propane torch to melt the bushing.
« Reply #51 on: January 27, 2009, 11:47:15 PM »
Gasoline?  Propane Torch?
Mitch, how many fire extinguishers have you got on hand?  Also, who's bringing the video cam?
  • 4wd Pts: 17
« Reply #52 on: January 28, 2009, 12:02:30 AM »
Now we're really livin' up to the MOD DAY OF DOOM... DOOM.... doom.... doom...... doom.....
Soylent Yellow
  • 4wd Pts: 5254
« Reply #53 on: January 28, 2009, 07:00:00 AM »
I need the gasket because I have a spiffy way of doing this.  I have all the brackets and stuff the diff attaches to so I will prep them with then new bushings and then remove and replace the old ones.  The bonus is that the diff gets fresh oil in the process.
I'll start sending out my address tonight.
« Reply #54 on: January 28, 2009, 07:48:09 AM »
I am thinking more along the lines of sawza. Somthing about Mitch and Fire concerns me. It might be safe since Frank will be there but I dont know.....
Once the spacer is out. There still is the problem of getting this metal sleeve out that was once attached to the spacer. This is the part that has me wondering.
« Last Edit: January 28, 2009, 07:52:52 AM by fleury123 »
« Reply #55 on: January 28, 2009, 10:55:33 AM »
. . . It might be safe since Frank will be there but I don't know.....
You're right to say "but I don't know...".  If I see fire coming from under a truck with a 20 gallon gas tank, and all I've got in my hand is a piss-ant little fire extinguisher, you can be pretty sure that my basic survival instinct will override my other senses and I'll be running down the street screaming wildly. Come to think of it, I may park my truck a few doors down too.
« Last Edit: January 28, 2009, 11:26:28 AM by FrankB »
« Reply #56 on: January 28, 2009, 10:59:35 AM »
Chris, Can you please sent me the instructions?
« Reply #57 on: January 28, 2009, 11:07:18 AM »
look at one of my previous post from yesturday and it is attached
« Reply #58 on: January 28, 2009, 11:53:06 AM »
wow it took me forever to find that.  THe attachements shoudl be bold of something
« Reply #59 on: January 28, 2009, 12:50:49 PM »
Well tell the admin. I am not given any suggestions......
