Author Topic: Cleveland Nat' Forest Trip  (Read 41512 times)
born to go
Re: Cleveland Nat' Forest Trip
« Reply #45 on: November 15, 2012, 07:38:31 AM »
Awesome guys thanks for the advice all get to spending money
« Reply #46 on: November 15, 2012, 08:43:34 AM »
What about hand held radios, ive tried everywhere local to long beach that i can think of and no one carries Cb supplies Any segestions local where i can get the gear or what hand held to get.
Thanks
Some of the Amazon deals here in link form:
Midland Handheld All-In-One - For 12 Volt Plug N' Play
Midland Standard 40 Channel - For Hard Wiring
Midland Magnetic Mount Antenna with Coaxial Connector (works with both radios above)
Firestik Antenna Kit Page
The Club uses FRS for some runs still, but IMO CB is the better option for several reasons.
Getting a CB installed, whether it is temporary through the 12V in car outlet (cigarette lighter for those of us over 40) for power and a magnetic mount for the antenna, or hard wired to the battery with an installed Firestik antenna, will help you communicate much clearer and reliably than FRS.
Installing a CB is a great first mod, that familiarizes you with the basic electronic principles of your Xterra as well as some of the tools necessary to build a good tool kit.
These are all things that SCCX promotes...familiarity with your truck, a well prepared driver...and an empty wallet. ;)
It is up to the trail leader to set the comms of choice for each run and follow through with channel sets etc.
This is also the preferred method of comms for several other SoCal Off Road Clubs (JustRuns, Tierra Del Sol) so if you choose to run with them in the future, you are good to go.
Once you are comfortable with the CB...I will gently nudge all members in the direction of The 35 Question Test To Clear Communications Forever.  ;)
« Last Edit: November 15, 2012, 08:57:52 AM by GhostX »
hunter0389
« Reply #47 on: November 15, 2012, 10:58:45 AM »
Thanks for the suggestion.  I was looking at the hand held from Amazon.  I know nothing about CB.  So, is the hand held plus the magnetic mount antenna all I need?  Do I need cable or does the antenna come with cable that is long enough?  Do I need any other adapter?
I know if I ever go on the light trails with you fine folks, I would need a CB.  So, I've been looking.
2007 Solar Yellow
« Reply #48 on: November 15, 2012, 11:26:02 AM »
Yes, handheld is fine in this case with the mag mount.
Mag mount comes with the coax already attached.
You would just need to plug in the power cord to the 12 volt plug in your center console (Gen 2 Xterra), screw the antennas coax onto the radio, then fish the coax through a door, and stick the antenna to the roof.
« Reply #49 on: November 15, 2012, 11:43:04 AM »
I have a Firestik mag mount that I'm not using. PM me if you're interested.
« Reply #50 on: November 15, 2012, 03:54:49 PM »
Thanks
[/quote]
If you go to the West side of Long Beach, there are several Truck supply shops near Anaheim and Santa Fe that carry CB parts.
« Reply #51 on: November 15, 2012, 07:15:05 PM »
Thanks
Tim...I have a mag mount antenna someone gave me from BB...said it was yours?
Lava
  • 4wd Pts: 21
« Reply #52 on: November 15, 2012, 10:46:39 PM »
OP UPDATED ;D
I have a 4 Foot Antenna you can have if you buy the 3/8 mount for it. I went with a two footer from Firestik after whacking the 4 footer on every tree branch in county! I mounted the K-400 to high, and am to lazy to lower it.  >:(
PM me if your interested.  ;D
My other vehicle is an X-WING
Justin - KK6JEC
justin123560
« Reply #53 on: November 16, 2012, 12:33:01 AM »
OP UPDATED ;D
I have a 5-Footer and I always forget to take it off before I go into parking structures lol. All I hear is BAM BAM BAM and a lot of people looking at me.   :D
born to go
« Reply #54 on: November 16, 2012, 02:59:24 AM »
OP UPDATED ;D
Pm sent
Pro4X-Gremlin
  • 4wd Pts: 11
« Reply #55 on: November 16, 2012, 05:54:12 PM »
I got my midland/antenna at a truck stop. Yes. For realzzz...
Lava
  • 4wd Pts: 21
« Reply #56 on: November 16, 2012, 09:50:55 PM »
Dang! Truck stops are sketchy!!
 ;D
Justin - KK6JEC
« Reply #57 on: November 18, 2012, 12:17:56 PM »
I'm really looking forward to this run. The X has been too clean for too long.
Is the OHV park the same spot, down the trail from Santiago Peak?
Lava
  • 4wd Pts: 21
« Reply #58 on: November 18, 2012, 01:40:46 PM »
Its in the southern part of the CNF, south of the 74...
Website say currently CLOSED.....
It usually reopens after 24hours post rain/wet weather.
Justin - KK6JEC
« Reply #59 on: November 18, 2012, 02:39:15 PM »
I have a 5-Footer
Now your just bragging
