Author Topic: El Toro, let me introduce you  (Read 134439 times)
Re: Re: El Toro, let me introduce you
« Reply #120 on: March 13, 2015, 01:02:59 PM »
Updated rear end.......
Took her to the King this week.
http://tapatalk.imageshack.com/v2/15/03/13/d39f99eb80569cf54a42be9f8c9ce458.jpg
Rear spring perches were cut off and the diff was rotated for better driveline angles. Diff shock mounts were removed, boxed and raised up out of the way. Upper mounts were redone and raised to offset the lowers and strengthen. Rear right shock relocated to rear of diff to avoid oncoming hits.....again.....
http://tapatalk.imageshack.com/v2/15/03/13/b0d803cb0f7827ca0b49affcf112584b.jpg
http://tapatalk.imageshack.com/v2/15/03/13/b92d7539cf903382bebdced60cf3d538.jpg
Very satisfied with The King's top notch work!
« Reply #121 on: March 13, 2015, 01:16:33 PM »
Really nice job there those welds are super nice! I was wondering what kind of a formula did you use to set the new angle of the diff and did remounting your rear shocks add any overall height?
« Last Edit: March 13, 2015, 02:34:16 PM by Celt »
« Reply #122 on: March 13, 2015, 01:26:46 PM »
Maybe swap the horns for a crown? ;)
Looks great D.
Sent from Planet Claire
 using Tapatalk
« Reply #123 on: March 13, 2015, 02:27:22 PM »
Looks great D.
 using Tapatalk
That took me a second to get.
Horns stay for sure!
Now, crown on top of horns?  DEFINITELY!
« Reply #124 on: March 13, 2015, 03:16:07 PM »
The King = The Mad Scientist = The One and Only Kenny.
« Reply #125 on: March 13, 2015, 04:34:45 PM »
Lol...yup.
 using Tapatalk
« Reply #126 on: March 13, 2015, 10:57:11 PM »
WOW :o  ??? ???
« Reply #127 on: March 13, 2015, 11:14:26 PM »
Damn that looks nice D.   Think I may need a trip to the King myself  :-)
chrishaynesusa
  • thenewx
  • 4wd Pts: -35
« Reply #128 on: March 14, 2015, 09:15:51 AM »
missing pictures of your new Refrigerator.....
installed of course
« Reply #129 on: March 20, 2015, 05:55:21 PM »
Got the latest Frontrunner Rack today. It's only about 1.5 inches lower, but it makes a world of difference.
http://tapatalk.imageshack.com/v2/15/03/20/11edf22821d5c2b49aaeec45f34a2292.jpg
http://tapatalk.imageshack.com/v2/15/03/20/45fe0d3db94f053d8206f60c07e10d69.jpg
I'm glad they retained it's ability to carry a table undeneathe it.
   They are still toying with the idea of lowering it further and extending the front.
   I also picked up their 13 gallon water tank that fits perfectly behind the rear seats.http://tapatalk.imageshack.com/v2/15/03/20/42e6c54623d292c639b8207b644cc0d7.jpg
Here it is with the fridge...it's a snug fit but it works well.
You all should consider one of these tanks. They are perfect! The added weight is right over the diff too.
   Give Steve at frontrunner a call.
« Reply #130 on: March 20, 2015, 06:49:56 PM »
Interesting.  Can you play ping pong on that table? ;D
I do like that water tank.
« Reply #131 on: March 20, 2015, 09:43:20 PM »
Very nice
« Reply #132 on: March 21, 2015, 06:19:10 AM »
quantos?
« Reply #133 on: March 21, 2015, 10:20:25 PM »
quantos?
That is a pretty spiffy rack Toro, but I would imagine it can get pretty expensive when you start adding all of the accessories/clamps/attachments? That water tank is pretty cool, too. Is there any way to pressurize it?
« Last Edit: March 21, 2015, 10:23:59 PM by JFanaselle »
« Reply #134 on: March 21, 2015, 11:15:13 PM »
    If your pressurizing a tank, it'd be best to do it on a tank that's mounted high and assisted by gravity. This tank, when full, weighs over 100lbs and will be in the rig. The best way to get pressure out of something like this is to run a pump on the outlet. The tank comes with a 1/2 I.D. ball valve so it will flow like a mo-fo.
   We have 3 kids and do an ass load of camping. Our current 5 gallon drinking water setup doesn't cut it anymore and needed a serious upgrade. With all the hiking, camelbacks and cooking pasta between all of us, this should hold us for 4-5 days....
....shoot, I might even be able to wash my hands from time to time.
