How cute! It's so yittle!
A comment from the a structural engineer in my office. Consider trussing on each side to the hitch tube, you have a week spot that could bend both sides around the center tube. Angle or 3/16" plate would take care of it.
I absolutely agree...hence the
Rudimentary frame mock up
....statement.
The front will be triangulated and all joints will be gusseted. I intend to 45 bevel every joint to allow for a better weld penetration.
The trailer will be small..very small.
This is my 1st build, and although no corners will be cut, I intend to use this as a learning experience. This trailer will be sold to help fund the build I truly want.
There will also be "C" channel rocking to keep the frame from twisting.
