Author Topic: El Toro, let me introduce you  (Read 134300 times)
Re: Re: Re:
« Reply #60 on: April 05, 2014, 04:15:03 PM »
Mojave Road preparations in progress.
Removed all the skid plates
Changed all fluids
Raised the rear end
Re-Installed the rad skid.
Going bottom less for this run. Hopefully lightening the load just a bit.
« Reply #61 on: April 05, 2014, 04:41:12 PM »
Not a bad idea on lightening the road
Sent from my HTC One using Tapatalk
Re: El Toro, let me introduce you
« Reply #62 on: April 05, 2014, 10:00:59 PM »
Pants not required king of trip huh
npgtech
    • 2010 Xterra / 2015 Frontier
« Reply #63 on: April 08, 2014, 03:44:27 PM »
So don't run skids???
« Reply #64 on: April 09, 2014, 07:09:06 PM »
Na... just me. I took them off to do all the fluids. I just left them off. I never removed the gas tank skid and only reinstalled the rad skid.
Sent from my SM-T520 using Tapatalk
Re: Re: El Toro, let me introduce you
« Reply #65 on: May 04, 2014, 06:37:41 PM »
So this happened....
« Reply #66 on: May 04, 2014, 07:19:55 PM »
So like, how do you fix that?
SD_Frontier
« Reply #67 on: May 04, 2014, 07:21:58 PM »
Well that's a drag. What's the story?
Code Name: SHAMU
Build Thread
« Reply #68 on: May 04, 2014, 07:38:01 PM »
Ooooo.. Check the upper too
« Reply #69 on: May 04, 2014, 07:47:28 PM »
Ummm.... that doesn't look good I think.. it sorta looks a failed weld but hard to tell
Sent from my SCH-I535 using Tapatalk
« Reply #70 on: May 04, 2014, 08:16:20 PM »
So what happened?  Trying to get major air or something?
LupinOne
  • 4wd Pts: 13
« Reply #71 on: May 04, 2014, 08:42:27 PM »
ouch...... saaaaaaad daaay....  :o
John "LupinOne"
KF6BRF
« Reply #72 on: May 04, 2014, 09:05:57 PM »
That is the factory lower mount, sheared in half.
   Spent the weekend in Kennedy and Troy Meadows. Did some wheeling and fishing...then noticed it yesterday night. I'm not sure when it happened but I drove it home, 5 hrs, like that.
« Reply #73 on: May 04, 2014, 09:11:37 PM »
Time to go SOA with a D60. ;)
« Reply #74 on: May 04, 2014, 09:18:49 PM »
^ X2
