Author Topic: El Toro, let me introduce you  (Read 189158 times)
Re: El Toro, let me introduce you
« Reply #270 on: June 03, 2016, 11:57:08 AM »
Wheels mounted.
Here we gooooooooooo!
« Reply #271 on: June 03, 2016, 07:26:48 PM »
Sweet.
Jayrat
  • 4wd Pts: -669
  • FLBLFY
    • 2013 X
« Reply #272 on: June 03, 2016, 08:40:11 PM »
Very Nice indeed O0
You can pick your nose & you can pick your friends,   But you can't wipe your friends under the couch
« Reply #273 on: June 05, 2016, 11:10:28 AM »
is the trailer done yet to put the wheels on? :D
« Reply #274 on: June 05, 2016, 06:27:55 PM »
1st round of chopping and tac-ing will probably take place this weekend.
   I will be going with a 4'x5' box. This will be min amenity, max utility.
CVXTERRA
  • 4wd Pts: 18
« Reply #275 on: June 05, 2016, 09:09:49 PM »
Super excited to see this thing progress. Going to be pretty bitchin'.
« Reply #276 on: June 13, 2016, 06:40:10 PM »
Axle mock-up. I love it when math comes together.
Pretty much dead on stock width.
« Last Edit: June 13, 2016, 08:52:40 PM by Toro »
« Reply #277 on: June 14, 2016, 09:45:16 AM »
damn....that really looks great man.....and I do miss that sexy rear end of yours.... ;) ;) ;) :-* :-* :-*
Riz98
  • 4wd Pts: 8
  • PBR ASAP
    • 2002 Nissan Xterra
« Reply #278 on: June 19, 2016, 08:32:04 PM »
Nice tires..... :)      Looking forward to seeing the completed setup.
« Reply #279 on: June 24, 2016, 05:31:16 PM »
Rudimentary frame mock up complete.
   Hopefully I can tac this up and mount the suspension soon.
steve c
  • 4wd Pts: -1577
    • 2012 Pro4Steve
« Reply #280 on: June 24, 2016, 08:06:28 PM »
You're a stud.
Can't wait to watch the progression   O0
Steve - KK6OFL
ERMAHGERD CLICK ME  <--- (Build Thread Linky)
CAWoody
  • 4wd Pts: 72
    • 2018 Toyota Tacoma (Really miss the X)
« Reply #281 on: June 26, 2016, 08:17:32 PM »
How cute!  It's so yittle! :D
A comment from the a structural engineer in my office.  Consider trussing on each side to the hitch tube, you have a week spot that could bend both sides around the center tube. Angle or 3/16" plate would take care of it.
Be careful when you follow the masses..... sometimes the "M" is silent.
« Reply #282 on: June 26, 2016, 11:09:26 PM »
I absolutely agree...hence the
....statement.
The front will be triangulated and all joints will be gusseted. I intend to 45 bevel every joint to allow for a better weld penetration.
The trailer will be small..very small.
   This is my 1st build, and although no corners will be cut, I intend to use this as a learning experience. This trailer will be sold to help fund the build I truly want.
    There will also be "C" channel rocking to keep the frame from twisting.
« Last Edit: June 26, 2016, 11:12:39 PM by Toro »
« Reply #283 on: June 27, 2016, 04:51:40 PM »
Spend a little time over on the Tventure forum...lots of great frame tips over there.
Sent from Cygnus-X1
« Reply #284 on: September 01, 2016, 09:03:20 PM »
Many projects in the works.
- 2nd battery bought, box is built and mounted. Need to run 0/2 wire.
- solar charge controller wired and ready for panel.
- side lights purchases and wired.
Need to build brackets.
- full pads/rotors/ebrake in hand, need to install them.
- new CB/ham ant mounts and cables ready for new masts (I still need to buy).
Not to mention the trailer.......
New tires and rebuilt suspension is in the wings.
  Soooooooooo behind on where I'd like to be.
Sent from my SAMSUNG-SM-G891A using Tapatalk
