Author Topic: Truck Haven  (Read 45400 times)
justin123560
Re: Truck Haven - January 26, 2013 *DATE CHANGE*
« Reply #90 on: January 21, 2013, 08:59:17 PM »
I have a pair off the R180 in my frontier before I t-swapped, they are the same right?
Yes they are the same
« Reply #91 on: January 21, 2013, 09:30:06 PM »
I would say that they are.   Do you want to sell them?  Where are you located?   I already know I need one right now possibly both.
(Seven one four) 271-three 5 seven 1
Unbreakable
« Reply #92 on: January 22, 2013, 01:23:36 AM »
The book California Trails shows Truckhaven Trail (SC#26)W to be NE of Borrego Spriogs but N of Ocotillo Wells and directly E of the Salton Sea along the main S22 road.  It also crosses three other trails, SC#27, SC#28. and SC#29.  Expect to do around 11.5 trail miles and a difficulty rating of 5 (a detour around the washout is rated a 7 in reverse, an 8 going forward and is the only way around).  There is a possibility of damaging the sides of your vehicles if you slip sideways on the loose surface.  Its a short pinch that is very steep.
Looking at Backcountry Adventures Southern California, it looks like you can avoid the 8 rated section by jumping down south to the Arroyo Salado Trail SC#28 if you find the recent rains make it such that you want to avoid the tougher section.  If you are starting at S22 near Inspiration Point Wash, you will have already done most of Truckhaven Trail SC#26 by then.  Here is what makes me think you can choose the alternate trail (head right instead of left).  Keep in mind, the book I have was published in 2002.
"Turn left up unmarked Truckhaven Trail #26 and zero trip meter.  South Coast #28 Arroyo Salado Trail is on the right.  Intersection is easy to miss in this direction."
Here's what the trail guide says if you continue north on Truckhaven Trail SC#26,
"The official road is washed out and impassable; there is a difficult loose, alternate route immediately upstream before the main trail junction.  It is very difficult in this direction because of the loose surface.  Care is needed on this ascent at a tight twist on top of the short rise."
I think that is the section shown in the video.  I certainly don't mean to discourage anyone, but just thought I would offer a possible alternate route if needed.  Here is a map of the area.
http://www.desertusa.com/anza_borrego/abphoto/ABDSPmap.pdf
holy molar...starting to think this isnt for me  :-[
Lava
  • 4wd Pts: 21
« Reply #93 on: January 22, 2013, 02:57:05 AM »
Ahhhh. That makes sense. When I read this stuff at 3am I'm in another planet.
Well, it sounds like those guys you wheel with are saviors in making the toughest impossible recovery jobs, painless and expedient.
It's always good to stop and help someone out on the trail...even if they drive a Tacoma and smoke to much weed.  ::)
My other vehicle is an X-WING
Justin - KK6JEC
« Reply #94 on: January 22, 2013, 06:36:59 AM »
I will map out a run that will be enjoyable for everyone. No one wants to stress out on, what is supposed to be, an enjoyable day of wheeling.
SD_Frontier
« Reply #95 on: January 22, 2013, 06:53:42 AM »
If I recall correctly, ultrapc40 and I went through Truckhaven trail with a TDS guy and got to the fireplug and the phone booth. And i was in my 05 Frontier with only 33s and barely a 3" front lift. There was also a stock 1st gen X with us. And we all made it with no problems.
Code Name: SHAMU
Build Thread
Unbreakable
« Reply #96 on: January 22, 2013, 10:08:30 AM »
ooo ok then count me in Ray...thank you for the confidence  ;D
« Reply #97 on: January 22, 2013, 10:20:23 AM »
Rain in the forecast!!
YESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
RockinX
  • 4wd Pts: 33
« Reply #98 on: January 22, 2013, 12:04:42 PM »
In Southern California, I don't think 10% chance of rain counts. :P
« Reply #99 on: January 22, 2013, 12:58:12 PM »
Do you guys still want to do this run, if it rains?
« Reply #100 on: January 22, 2013, 01:03:45 PM »
HELL YES.  Pardon my french.
SD_Frontier
« Reply #101 on: January 22, 2013, 01:16:42 PM »
Well I'm officially out. Wife needs to go to a baby shower and I need to babysit. I'm sad to miss this but I'm hoping there is another run in Feb.
Code Name: SHAMU
Build Thread
mark1107
  • 4wd Pts: -6
« Reply #102 on: January 22, 2013, 03:06:48 PM »
Is anyone camping? Mark and Nia want to do the run but after wheeling all day it's a hassle to drive home. So if nobodys camping we will pass. If anyone's camping were probably in...
dan826
« Reply #103 on: January 22, 2013, 03:33:31 PM »
I'm still in rain or shine, although the rain is pretty remote possibility at this point.
« Reply #104 on: January 22, 2013, 04:05:14 PM »
This run is hard enough when the conditions are dry.
For the good of everyone involved, this run will depend on the weather. If it rains, the run will be rescheduled. :'(
I DO NOT want to put anyone into harms way.
This is a social club, far be it from me to tell anyone what to do, so please be understanding. If it rains, and you're still planning on running Truckhaven, please be careful.
