Author Topic: 0317's SAS'D X  (Read 97788 times)
ShockBlue_Scott
    • 2002 Xterra
Re: 0317's X
« Reply #15 on: June 23, 2013, 10:37:24 PM »
Looks good brother
Scott
2002 Nissan Xterra Shock Blue
City Heights, San Diego CA
DocNasty
Re: 0317's X
« Reply #16 on: June 24, 2013, 05:56:54 AM »
What unit are you with bro? I was with the STA plt out of 1/1 in Horno.
Re: 0317's X
« Reply #17 on: June 24, 2013, 08:18:58 AM »
Re: 0317's X
« Reply #18 on: June 24, 2013, 08:21:29 AM »
I was with 2/4 SSP out of Mateo. STA no longer exists, at least not in the 5th Marines.
Re: 0317's X
« Reply #19 on: June 26, 2013, 09:49:20 PM »
This is what my X wants to be when it grows up.
http://www.clubxterra.org/forums/showthread.php?p=626793#post626793
Re: 0317's X
« Reply #20 on: July 26, 2013, 12:54:21 AM »
« Last Edit: July 26, 2013, 12:56:09 AM by 0317 »
Re: 0317's X
« Reply #21 on: July 27, 2013, 11:12:40 AM »
That's Tim Ray...now with LetzRoll Racing.
Re: 0317's X
« Reply #22 on: September 22, 2013, 12:19:27 PM »
Nice! Gotta love the SAS  ;)
ShockBlue_Scott
    • 2002 Xterra
Re: 0317's X
« Reply #23 on: October 14, 2013, 09:56:33 AM »
Looks good
Scott
Re: 0317's X
« Reply #24 on: November 08, 2013, 08:03:48 PM »
Nice pics. Looks like it was a good run.
Re: 0317's X
« Reply #25 on: March 27, 2014, 07:03:00 PM »
Picked up a Tx10 from an 88 Pathfinder.
Plan: Rebuild internals and install AC crawler gears, then swap out the Xterra Tx10.
Why? 88 Pathfinder Tx10 has a larger stronger chain than a 04 Xterra Tx10. Stock to stock nearly twice as strong. Will be easier to work on the 88 Tx10 than to remove the 04 Tx10 and work on it. Once 88 Tx10 is ready, will do the swap. (was told they share the same exterior housing and will bolt in the same)
Will be a slow process, but hey its a start in the right direction.
« Last Edit: March 27, 2014, 08:45:49 PM by 0317 »
Re: 0317's X
« Reply #26 on: March 27, 2014, 10:20:39 PM »
Good find James.  You're in no hurry, you haven't even broken the stock one yet ;D
Re: 0317's X
« Reply #27 on: March 27, 2014, 10:28:58 PM »
That's true, but I want those crawler gears.
Re: 0317's X
« Reply #28 on: March 27, 2014, 11:05:09 PM »
Nice James...with 5.13's and that TC you should be able to climb walls.
Re: 0317's X
« Reply #29 on: July 03, 2014, 08:11:57 PM »
I finally got around to redoing my storage area.
All credit goes to sionnach from clubxterra.org for designing the box. (http://www.clubxterra.org/forums/showthread.php?t=36778 )
His write up and pdf made this project very simple. Although some knowledge on cabinet work is needed along with proper tools.
From beginning to end, the project took me approximately 36 hours of labor over 6 days.
« Last Edit: January 05, 2018, 06:39:26 AM by 0317 »
