Author Topic: KickinTires' 2011 Avalanche PRO-4X Frontier  (Read 17958 times)
KickinTires
  • 4wd Pts: 9
« on: June 19, 2013, 10:10:26 PM »
Joined SCCX: May 01, 2011
Username:  KickinTires
Real Name: Mark
Year:  2011
Make:  Nissan
Model: Frontier (Crew Cab)
Trim:  4x4 PRO-4X 6-spd
Color:  Avalanche White
Mods:
   Suspension:
         PRG UCAs
         2.0 PRG Radflo Coilovers
         Bilstein 5125 0-3" Lift
         PRG Deaver AAL
    Wheels and Tires:
         BF Goodrich All-Terrain K/O (265/75/16)
    Armor:
         Shrockworks Sliders, Rear Diff Plate
         Shrockworks Skids;
            Engine, Transmission, Transfer Case, Gas Tank,
             and Radiator
   Communication:
               Midland 1001 LWX
               Firestik 18' Coax
                Firestik Firefly 3' w/ Firestik Quick Disconnect
   Extras:
         Leer 700 tonneau cover
         Nissan hood protector
         XPEL lens kit
         RotoPax 3-Gal w/ Utilitrac Mount
         Hi-Lift Jack /w Titus Products Hi-Lift Mount
         Bumper mounted Trailer Harness Receptacle
         Pathfinder Switch Plates
   Future Mods:
         BlueSea 12-Fuse Curcuit
         Direct wired; GPS, CB, and Inverter
         Anderson Powerpole  6ft Pigtail for Air Compressor
         ARB or CVT Awning mounted cross-wise underside of Tonneau w/ side curtains
         Roof Rack Rails on Tonneau w/ BajaRack of some sort???
Comments:  I wanted a very capable rig for running Greens and some Blues and basically get my Camera further off the pavement!
Photos:  Some of my Mods and Outings with SCCX and friends...
Stock off of Dealers Lot...
Leer 700 Tonneau Cover..
ShrockWorks Sliders Installed...
ShrockWorks Skids and Diff Plate installed...
New BFG All-Terrains...
PRG UCAs and 2.0 PRG Radflo Coilovers
Lifted just right...
Trailer Harness Bumper Mod...
CB Antenna Mount...
CB Out of Service...
First Run w/ SCCX - Buttes Pass Area
SCCX Run - Blair Valley
SCCX Run - Big Bear - CANVAS 2012
« Last Edit: June 20, 2013, 06:56:49 PM by KickinTires »
Mark
Club Frontier Member "KickinTires"
SD_Frontier
Re: KickinTires' 2011 Avalanche PRO-4X Frontier
« Reply #1 on: June 20, 2013, 12:33:33 AM »
Clean!
Code Name: SHAMU
Build Thread
« Reply #2 on: June 20, 2013, 05:39:48 AM »
Very nice.   TOO clean   ;)
Motorpig77
  • 4wd Pts: 31
« Reply #3 on: June 20, 2013, 10:46:26 AM »
Nice truck!  Do you have any pics of the rotopax 3gal utilitrack mounts?
« Reply #4 on: June 20, 2013, 12:59:45 PM »
Yep, deff getting a Frontier.
KickinTires
  • 4wd Pts: 9
« Reply #5 on: June 20, 2013, 06:51:14 PM »
I can take some for you if you'd like.  Not really impressed with the Utilitrak mount.  It is rather flimsy and that 3 Gal Pak with it's weight will be vibrating all over the place.  I'm going to a least make a brace to connect to the trak on the floor at that end of the bed...
I'm still running around town with the dirt from Mojave Road; does that count?
« Last Edit: June 20, 2013, 06:52:49 PM by KickinTires »
Mark
« Reply #6 on: June 21, 2013, 06:18:04 AM »
Seriously...no kidding.
KickinTires
  • 4wd Pts: 9
« Reply #7 on: June 29, 2013, 05:53:50 PM »
Motorpig77;  Sorry, it took me awhile to get these posted...
Here are a couple of the Utilitrak mount as attached to the trak, the top is generally secure, but the plate with the weight has nothing to stop it from vibrating fore/aft.
I just want to attach a short 'L' brace from the floor trak to the bottom of the plate.
Now with the 3 Gal RotoPax mounted, it clears well on top and bottom
That's it, I'm sure it can be improved.   Maybe the entire mount can be a DIY project as well...
« Last Edit: June 30, 2013, 11:01:32 AM by KickinTires »
Mark
Motorpig77
  • 4wd Pts: 31
« Reply #8 on: June 30, 2013, 01:12:26 AM »
Thanks for the pics...I can see where it could use some reinforcing to make them more stable back there. I'll look into it and see what I can up with!
SD_Frontier
« Reply #9 on: June 30, 2013, 09:15:03 AM »
Ooh I like those. I might mount my hi lift vertically and get some rotopax and mounts. Lemme know how you reinforce the bottom.
Code Name: SHAMU
Build Thread
