Author Topic: LupinOne  (Read 29719 times)
LupinOne
  • 4wd Pts: 13
Re: LupinOne
« Reply #30 on: May 02, 2014, 12:12:52 AM »
- Installed Midland CB with Bandit RF filter and "Little Wil" antenna.
- Installed Highlift Jack with Neoprene Cover and Nisstec Lotus Slider Adapter on Highlift Tube mounts (during Mojave Road run... thanks Terry!) (with functional test... :P )
John "LupinOne"
KF6BRF
LupinOne
  • 4wd Pts: 13
Re: LupinOne
« Reply #31 on: May 04, 2014, 08:43:27 PM »
- Removed and jettisoned defective Midland CB.  Installed new Uniden 520XL unit and external speaker.
John "LupinOne"
KF6BRF
« Reply #32 on: May 05, 2014, 12:25:00 AM »
Just an fyi about the fire extiguisher, Might want to look into a halon or co2 extinguisher instead of dry chem, dry chem is very corrosive and expensive to clean up because its hazmat, even if your vehicle doesn't burn to the ground, its totaled in the insurance companies eyes.  Halon is similar to co2 but doesn't displace oxygen like co2 so you don't go night night if it happens to rupture in your vehicle.  They are less effective on class A fires(stuff that leaves an ash) but will work.
Sent from my HTC One using Tapatalk
LupinOne
  • 4wd Pts: 13
Re: LupinOne
« Reply #33 on: May 19, 2014, 08:38:29 PM »
-sniffs- It's so beautiful.  My X finally has a great front and rear bumper. :)  Pics in first post. :)
John "LupinOne"
KF6BRF
Re: LupinOne
« Reply #34 on: May 28, 2014, 10:17:26 AM »
JF, can you post up some details/link regarding the LED awning light?  Does it roll up with the awning or separately?
Thanks in advance!
JT3/GhostX
Re: LupinOne
« Reply #35 on: May 28, 2014, 11:19:24 AM »
from what i saw john its mounted on the inside of the aluminum part thats mounted to the roof rack, in the area where the 2 horizontal poles get stored. i think its a standard option on the ironman awnings but could easily be added to the arb if you could find an led strip that has double sided tape on the back and a cig lighter adapter.
Re: Re: Re: LupinOne
« Reply #36 on: May 28, 2014, 06:40:46 PM »
Thanks in advance!
JT3/GhostX
www.amazon.com/dp/B00ENX0VUE/ref=cm_sw_r_udp_awd_T9OHtb07A03TT
Goes in the track and stays there. Cut it to length and BAM!
LupinOne
  • 4wd Pts: 13
Re: LupinOne
« Reply #37 on: May 29, 2014, 07:42:13 AM »
^^ What he said.   Yes, its standard from Ironman and just stuck in there. Hides nicely. :)
John "LupinOne"
KF6BRF
Re: LupinOne
« Reply #38 on: May 29, 2014, 08:40:24 AM »
Very cool...thanks guys.
Now, about the color choice.... ;D
Re: LupinOne
« Reply #39 on: May 29, 2014, 01:10:20 PM »
i have some of that exact LED strip on my quadcopter, with about 4m extra haha, let me know if you want some john.
LupinOne
  • 4wd Pts: 13
Re: LupinOne
« Reply #40 on: December 01, 2014, 11:08:30 AM »
Upgraded on board communications, removed FT-7900R/E, installed FT-8800R.
Still dual band Ham Radio, but now full cross-band repeater capable.
John "LupinOne"
KF6BRF
LupinOne
  • 4wd Pts: 13
Re: LupinOne
« Reply #41 on: February 15, 2015, 11:00:50 PM »
Upgraded antenna coax and relocated antenna's for low profile and max efficiency.
Added Bully Dog Gas Tuner for ECM monitoring.
John "LupinOne"
KF6BRF
Re: LupinOne
« Reply #42 on: February 16, 2015, 05:20:44 AM »
Cool.  The Bully Dog is a good asset.
LupinOne
  • 4wd Pts: 13
Re: LupinOne
« Reply #43 on: May 06, 2015, 06:29:19 PM »
Installed some new electronics:
- Added Bluesea 12 Circuit DC Buss
http://i1296.photobucket.com/albums/ag15/jferdon/Modification%20Projects/06E43F9B-F1D7-4579-8802-5E4BB0E63010_1.jpg
LupinOne
- Installed Byonics APRS
- Installed Point-1 sensor giving NMEA2000 network for HDS-7M
Pass through for data cable
http://i1296.photobucket.com/albums/ag15/jferdon/Modification%20Projects/08410F22-6B5D-4B2F-AA1B-BA3BACA5F426_1.jpg
LupinOne
Routing data cable above rear windshield fluid tubing and airbag
http://i1296.photobucket.com/albums/ag15/jferdon/Modification%20Projects/14FB625C-4DA3-44E6-92C9-2F4E0A23976C_1.jpg
LupinOne
http://i1296.photobucket.com/albums/ag15/jferdon/Modification%20Projects/FD77A40B-407A-4F39-BEA9-D7B4EC5B3C6F.jpg
LupinOne
Our Supervisor...
http://i1296.photobucket.com/albums/ag15/jferdon/Modification%20Projects/EBE8EF8B-D25F-4D8C-B2BC-DBA6157C03F6_1.jpg
LupinOne
- Installed Lowrance HDS-7M GPS
Opening up for cable runs and switching installation
http://i1296.photobucket.com/albums/ag15/jferdon/Modification%20Projects/0A007A23-D2EC-45B8-A2CD-9622209D368F_1.jpg
LupinOne
Steve, Kenny, and some very cool toys...
http://i1296.photobucket.com/albums/ag15/jferdon/Modification%20Projects/A6E661E1-1FBA-4DB5-8156-2A399EB1347A.jpg
LupinOne
Mocking up the mounting bracket
http://i1296.photobucket.com/albums/ag15/jferdon/Modification%20Projects/4634D20B-8405-483B-AE7B-64F97414EFBD.jpg
LupinOne
Getting closer...
http://i1296.photobucket.com/albums/ag15/jferdon/Modification%20Projects/C35EA6D0-AC47-413A-94A4-D2806867CC0B.jpg
LupinOne
I love the smell of Argon in the evening...
http://i1296.photobucket.com/albums/ag15/jferdon/Modification%20Projects/A529FBCB-BB41-4B13-9B5C-C2F2448AB9A3.jpg
LupinOne
Up and running!
http://i1296.photobucket.com/albums/ag15/jferdon/Modification%20Projects/2C974868-5FC5-49A9-AD56-B25AD17893D6.jpg
LupinOne
Special shout out and thanks to Kenny "The King" and Steve for late night fabrication fun. :)
Now to get some wheeling in and really put it through its paces!
« Last Edit: May 06, 2015, 07:38:53 PM by LupinOne »
John "LupinOne"
KF6BRF
Re: LupinOne
« Reply #44 on: May 06, 2015, 08:10:06 PM »
That's RAD!  Good work John!  (and Kenny and SteveO)
Can't wait to check that our in person.
