Author Topic: Kurt765's Lava Red Pro 4X  (Read 8456 times)
kurt765
« on: July 07, 2013, 06:07:04 PM »
Joined SCCX: October 2012
Username: kurt765
Year: 2011
Make: Nissan
Model: Xterra 4x4
Trim: Pro 4X, Leather
Color: Lava Red
Mods since I bought it:
Replaced stock Rugged Trail tires after 34k with BFG All terrain K/O in stock size (LT265/75/R16)
Added hood deflector, window deflectors
White Knuckle rock sliders (DOM steel, hand painted with POR15 and then Rustoleum matte black)
Garvin Hi-Lift roof rack mount, single shovel/axe mount
Future:
Replace front skids probably
CB radio install (HAM eventually likely)
Dual batteries
Bigger tires with melt mod if I move to a place with a higher garage clearance someday
Comments:
I love this thing. Took it to Saline Valley in Death Valley National Park last year all stock. Performed flawlessly. I got 34k out of the stock tires before replacing them with the now current A/Ts before an upcoming road trip. Installed the rock sliders myself with help of a friend. I would not recommend drilling into the frame as a fun time.
Photos:
Driver's side
Passenger side
Shovel mounted (going to have to do something about the point of the blade there)
Hi-lift mounted
Hi-lift mount detail
kurt765
Re: Kurt765's Lava Red Pro 4X
« Reply #1 on: July 07, 2013, 06:11:43 PM »
Per some recommendations over at thenewx, I'm going to switch the hi-lift over to the passenger side and the shovel to the driver's side to facilitate easier and safer access if I have to pull over to the side of the road and change a tire or something.
Also, more pics: http://www.sccxterra.com/smf/index.php/topic,1583.msg16106.html
« Last Edit: July 07, 2013, 06:13:17 PM by kurt765 »
Adio.
  • 4wd Pts: 10
« Reply #2 on: July 07, 2013, 07:26:49 PM »
How did you do those shovel mounts? I used pipe repair clamp for mine.
kurt765
« Reply #4 on: July 08, 2013, 07:04:47 AM »
Good call on the Hi Lift relo.
Nice build thread...and tire upgrade. The BFG's are great all around tires.
If your plan is to off road more maybe look into a nice set of deflators and a battery clip air compressor.
Good luck Kurt!
kurt765
« Reply #5 on: July 09, 2013, 07:24:43 AM »
Good luck Kurt!
I have a Superflow MV-90 and a set of deflators. Haven't used them yet, but I will. :)
« Reply #6 on: July 09, 2013, 11:02:32 AM »
I like where you're headed Kurt!
See ya on the trail ;)
SD_Frontier
« Reply #7 on: July 09, 2013, 11:22:54 AM »
Clean. A little too clean. Lets get this this dirty!
Hahah. Don't mind me. My truck is two tone and riddled with pinstripes.
Code Name: SHAMU
Build Thread
« Reply #8 on: July 09, 2013, 05:44:05 PM »
Nice.  :)
« Reply #9 on: July 14, 2013, 12:48:43 PM »
Nice build.
     If your worried about the shovel point, you can flip it around and slide towards the rear a bit. This way the point will wrap around the back of the roof rack. If you ever get stuck, you might want to consider a transfer shovel (with the flat edge). This will move a lot more material.
    See you on the trail.
DannyX
  • 4wd Pts: 23
  • "LIKE" Me on Facebook.
« Reply #10 on: July 19, 2013, 08:13:17 AM »
Great looking truck!! Let me know If you are ever in need of anything!! I alwayse like to take care of the local SCCX peeps!! http://www.offroadperformanceparts.com/
Also, any chance you know what part # that Garvin high lift mount is? I havnt seen that one before!
