Author Topic: Hanna Flat Campground Information  (Read 14236 times)
« on: August 12, 2013, 10:52:49 PM »
Steve...map is attached here.
Re: Hanna Flat Campground Information
« Reply #1 on: August 27, 2013, 01:41:11 PM »
Thanks, Ghost!
What tire pressure should I be running for 3n16?
« Reply #2 on: August 27, 2013, 05:33:50 PM »
12psi :D
« Reply #3 on: August 27, 2013, 08:44:07 PM »
Thanks, Ghost!
18/20 lbs. YES.
12psi :D
NO.
 ;D ;D ;D
« Reply #4 on: August 27, 2013, 09:26:53 PM »
BFG AT E load.
18/20?  Sounds good.
Jordan, I only run 12psi on my fatbike!   8)
http://imageshack.us/a/img829/6781/cdtv.jpg
Re: Re: Hanna Flat Campground Information
« Reply #5 on: August 27, 2013, 09:36:42 PM »
285, e load sidewall, stock wheels, 12 psi.  Yessss. 8 psi for deep sand, 12-15 for general offroading,  35-40 street.
18-20 won't even bulge the sidewalls, I'll compromise and go as high as 15, happy?
I'm going to air down to different pressures and make footprint sketches to prove my point
Not sent with the stupid auto guide app
SD_Frontier
« Reply #6 on: August 27, 2013, 11:12:54 PM »
Agreed. I don't even think 18-20 is enough on my BFG AT D Load tires. I'm usually down to 12-14 psi though my truck is lighter than an X.
Code Name: SHAMU
Build Thread
npgtech
    • 2010 Xterra / 2015 Frontier
« Reply #7 on: August 28, 2013, 09:36:36 AM »
Careful, GhostX knows how BFG react to 15 or less psi in them.  I know there are a few pics here that show it...
 ;D
« Reply #8 on: August 28, 2013, 01:42:19 PM »
John has skills no one can match, I regularly air down to 12 psi, bomb down washes at up to 70 mph, drifting and wallowing around and have yet to pop a bead.  It took 2 stuck open staun deflators causing me to run 2-4 psi for me to pop a bead at cleghorn.
« Reply #9 on: August 28, 2013, 01:48:07 PM »
 ;D
I'm still kinda new, but that doesn't look right.....does it?
SteeevO
  • 4wd Pts: 22
« Reply #10 on: August 29, 2013, 01:17:31 PM »
Looks like he pinched it to hard and Popped the bead. For the last 8 years I have run 12psi even without beadlocks.
If your sidewalls aren't buldging .. then you aren't aired down enough. IMHO if you're aired down and you have more than 15psi... then you might as well not air down.
Sent while mobile, typos likely.
« Reply #11 on: September 02, 2013, 01:24:06 PM »
We need a Ghost-isms thread. Blown beads, buried phones. ..the whole 9.
« Reply #12 on: September 02, 2013, 04:12:42 PM »
I'll vote for that too.   ;D
chrishaynesusa
  • thenewx
  • 4wd Pts: -35
« Reply #13 on: September 02, 2013, 06:46:51 PM »
Beadlocks for all my fiends  8)
« Reply #14 on: September 05, 2013, 04:39:38 PM »
Hey Ghost,
How many lbs. tire pressure does it take to bury a phone ???
