Author Topic: Skid plate question  (Read 8723 times)
Drew117
Skid plate question
« on: March 29, 2014, 09:33:39 PM »
Hey guys new member here and I just got a 2013 X and I love it but I took it to holy jim trail and hit a rock on my front skid plate. It's still on but it's bent and hanging lower. Does anyone know how much it would cost to replace with a stock front skid plate
« Reply #1 on: March 29, 2014, 10:12:47 PM »
Welcome from Pasadena.
   Don't bother replacing the skid with another stock skid. You'll only be replacing it again in no time flat.
Check out
http://www.heftyfabworks.com/shopping-cart.html#!/~/product/category=523179&id=2069010
Or
http://www.shrockworks.com/Gen2-Front-Radiator-Skid-Plate-Xterra-&-Frontier-pr-16178.html
Re: Skid plate question
« Reply #2 on: March 29, 2014, 11:33:06 PM »
You really WANT the skid plate to get banged up.  That's is its job.  To prevent importanstuff likd the motor or transmissIon from getting banged upYou could get a stronger and beefier skid plate.
« Reply #3 on: March 30, 2014, 07:08:37 PM »
Stock skids are one time use items..
Gotta get yer self some steel  ;D
Re: Re: Skid plate question
« Reply #4 on: March 31, 2014, 08:29:53 PM »
When they are new, they look like this.
When it's done right, they'll look like this.
« Reply #5 on: April 01, 2014, 08:25:06 AM »
What's even funnier is when you remember the rocks!!!
« Reply #6 on: April 03, 2014, 11:45:39 AM »
All of the above is great advice...IF you are on a budget, you can also scan thenewx.org For Sale forum for used Off Road/Pro-4X stock skid plates.
However, if you plan to do any serious off roading (and if you bent a stock skid plate already...you're there), this is something to upgrade ASAP.
Gents, correct me if I'm wrong here, but order of upgrade/install would be:
-engine
-transmission
-transfer case (besides your rear diff, the lowest contact point for rocks)
-radiator
-gas tank
-rear diff
A lot of people will install the gas tank skid last - but consider this - the stock replacement cost, just for the part, for an Xterra plastic gas tank is in the neighborhood of $1,200...while the skid plate will set you back about $200.
A full set of skids from the two manufacturers listed by Toro should set you back (with hardware, meaning nuts and bolts to mount all) between $750 and $1,000...still less than the replacement of your gas tank...the last thing you should protect.
Just a few more thoughts to clog your mod friendly brain... ;D
« Reply #7 on: April 03, 2014, 12:23:00 PM »
I don't agree.  Most of the polls i've seen regarding the order of upgrades has been like this:
-tires
-suspension
-communications
everything else based on budget...motor last.
Ultimately it comes down to personal preference and wallet.
« Reply #8 on: April 03, 2014, 01:16:09 PM »
i think order of upgrades is very dependant on what you what your truck  to do. i still have all the stock skid plates other than the rad skid that came with my hefty bumper, i dont do too much rock crawling, mostly desert running so for me skids are less of an issue.
for me it was tires, sliders, suspension, front bumper with a winch, then more suspension(TS swap for more speed to race raptors in the desert :D)
that said, if you dented a skid plate, i would only replace it with an aftermarket one.
« Reply #9 on: April 03, 2014, 04:33:25 PM »
-tires
-suspension
-communications
Um...weren't we referring to skid plates in this thread?
Re: Re: Re: Skid plate question
« Reply #10 on: April 03, 2014, 08:27:07 PM »
...John, please stay on topic....
« Reply #11 on: April 07, 2014, 10:00:50 AM »
OK PEOPLE, CALM DOWN!  We don't want to scare away the newbies... Unfortunately, the topic of what to get seems to be a very debated one.  We could go on and on.  Just remember that it all comes down to what you need.
« Reply #12 on: April 07, 2014, 11:44:36 AM »
-engine
-transmission
-radiator
-gas tank
-rear diff
To Drew117...I was referring to the order of upgrade/install for your skid plates in this post.  Sorry for the confusion.
« Reply #13 on: April 07, 2014, 12:29:05 PM »
 Actually, John is correct on that skid plate order.
LupinOne
  • 4wd Pts: 13
« Reply #14 on: April 08, 2014, 09:09:44 AM »
If you really want an OEM skid...tin...plate... :P  I have the set from my 2010.  They should fit no problem.  You are welcome to them as they are just taking room in my garage. Just shoot me a PM.
John "LupinOne"
KF6BRF
