Author Topic: Help lifting my new X  (Read 12331 times)
Drew117
« on: April 12, 2014, 10:05:24 PM »
I want to lift my 2013 Xterra about an 1.5 or 2". What's the best way todo that and how much? Any type of suggestions are welcomed. Thanks guys
Re: Help lifting my new X
« Reply #1 on: April 12, 2014, 10:57:22 PM »
how much money do you want to spend? and what are you planning on doing with your xterra?
Drew117
« Reply #2 on: April 13, 2014, 01:22:29 PM »
Nothing more than a grand. I just want to lift it about 1.5 or 2 inches  and I just some more cleanest from rocks
Xtracrispy
« Reply #3 on: April 13, 2014, 01:31:37 PM »
For that price range, you have OME(old man emu/arb), Nisstec adjustable coilovers, and Radflo or Sway-away for the front. Nisstec and PRG are the most well known vendors for all of those products. And you can get either Add A Leaf rear springs that will stiffen up th soft rear springs, and/or lift shackles. Plus a variety of rear shocks.
OME is cheapest, appx 1.5" lift and you can get just the front or a full kit. I have it up front and it's a decent setup, not top of the line but good improvement over stock.
No experience with Nisstec coilovers, but they are built off Bilstein 5100 shocks.
SwayAWay and Radflo, but at a higher price point. Better performance, though.
« Reply #4 on: April 13, 2014, 01:32:21 PM »
The cheapest way to do that is spacers and shackles or spacers and an add a leaf. Both of those are less then $500 ya can check out prg.
« Reply #5 on: April 13, 2014, 05:09:06 PM »
I have both the OME front coil sring and the med. duty rear leaf springs.  Paid @ $700 and works with the OE shocks.  its near top-of-the-line for weight management on the trail when loaded down with stuff.  the cool thing is you can always get better shocks down the road.
« Reply #6 on: April 13, 2014, 05:36:59 PM »
You can get a lot of nice gear for $1k.
    If your going to see real off road use, small to moderate rocks, dirt roads, washboard at moderate speeds....I say full Old Man Emo (ARB). Contact Steevo here on this board. He owns RuggedRocks.com, is local, wheels with us regularly and an all around cool cat.
   Struts, rear shocks, add-a-leaf at a fair price.
« Reply #7 on: April 13, 2014, 05:51:04 PM »
Yup, got mine ARB/OME stuff from Steevo.  he's your guy to set you up.
Drew117
« Reply #8 on: April 13, 2014, 11:02:41 PM »
Wow thanks guys for all the help! The X community is freaking awesome!!
« Reply #9 on: April 14, 2014, 09:47:56 AM »
Nisstec FTW. Ask for Chris Meisner.
2013nick
    • 2013 xterra S 4x4
« Reply #10 on: April 14, 2014, 10:10:50 AM »
Not to hijack your tread, but i also have a 2013 X and want to lift it, but i was thinking about 4-5 inches. BL is out of the question. so what is the best way to get 4 or 5 inches of lift without killing my wallet?
« Reply #11 on: April 14, 2014, 10:45:15 AM »
calmini 5 inch drop bracket lift is probably the only way to get 5" with enough downtravel to make it ride well. not cheap at $2200
2013nick
    • 2013 xterra S 4x4
« Reply #12 on: April 14, 2014, 10:59:32 AM »
What about a TS?
« Reply #13 on: April 14, 2014, 11:05:48 AM »
TS isn't so much about lift as it is about clearance; you'll widen by 6in overall, and gain a ton of travel, but if you want 5in that Calmini lift might be your only option
Why are you seeking so much lift?
« Reply #14 on: April 14, 2014, 11:40:03 AM »
you can achieve 5" of lift with a TS, but you will be really sacrificing downtravel, and that will just make it ride like crap, thus the comment about the calmini kit being your best option to retain a decent ride.
