Author Topic: Help lifting my new X  (Read 12329 times)
2013nick
    • 2013 xterra S 4x4
Re: Help lifting my new X
« Reply #15 on: April 14, 2014, 01:03:50 PM »
More lift more options... with 4-5 inches I could clear just about everything i would want to try and I like the way it looks
« Reply #16 on: April 14, 2014, 03:50:16 PM »
Well if ya do a ts ya can get 3-4 (which is where my X sits) and throw a body lift with bigger tires and you'll get the lift height ya want. Your diffs are always going to be your lowest point that you will have to worry about. I may be wrong but bigger tires are the easiest way to that diff higher off the ground
And also last minute though ya can always go spring over axle
Drew117
« Reply #17 on: April 14, 2014, 07:23:42 PM »
Oh another thing. I want the ride to still be really smooth even after I lift it
« Reply #18 on: April 14, 2014, 07:30:55 PM »
drew, for you i would put another vote for the ome stuff from nisstec, it will ride well and handle extra weight for camping and whatnot.
« Reply #19 on: April 14, 2014, 07:46:13 PM »
The magic number on our rigs is 3". Below that you can get a shackle and spacer kit for under $400 and a coil over kit at over $2k.
   Above 3" your looking at Titan Swapping or a drop bracket lift kit at mucho $$$$. The drop bracket kits out there do not include accommodations for the rear like a new driveshaft.
   A properly built rig can be fairly good on the original geometry.
« Reply #20 on: April 15, 2014, 07:42:29 AM »
I want to lift my 2013 Xterra about an 1.5 or 2". What's the best way todo that and how much? Any type of suggestions are welcomed. Thanks guys
Drew...back to your OP.  I ran a 2" PRG spacer/shackle lift for almost three years, and was very happy.  It gave the appropriate clearance for 285's (33" tires), and with some good spotting from friends, there wasn't too much my Xterra couldn't handle.
The PRG lift was $278 delivered back in 2010, and was one of my first installs/mods.  Solo, and with the first time removal of some of the "Nissan torqued" nuts and bolts, it took me about six hours.
PB Blaster is your friend, but it sounds like your X is fairly new.
 Keep in mind that any suspension mods can jeopardize your warranty, in Nissan's eyes of course.
« Reply #21 on: April 18, 2014, 04:49:42 PM »
I think the honest way of looking at this is that the more lift you want, the more its going to cost, the deeper your wallet has to be.  Other than a spacer and shackle, most kits will stiffen the ride a bit.  Softer may not be the best on the trails.  Why do you want 4-5" of lift anyways?  Most Xterra owners are happy with 3".
