Username: JFanaselle
Name: Joe Fanaselle
Vehicle info: 2010 Nissan Xterra S 4X4
Color: Avalanche WhiteTransmission: 5 speed automatic
Mods: (Updated 11/12/17) Drive Train/Performance:1. Rear axle assembly swapped from 3.13 C200 to 3.36 M226 w/ e-locker
2. Front diff swapped out to match 3.36 gearing after rear axle swap
3. Airflow snorkel
4. K&N drop-in air filter
Suspension/Tires:1. Radflo 2.5 extended travel front coilovers
2. PRG Rev 2 upper control arms
3. Camber bolts
4. Front sway bar delete
5. Rear sway bar delete
6. Old Man Emu Dakar HD rear leaf springs
7. PRG u-bolt flip kit
8. PRG rear adjustable shackles
9. Bilstein 5125 rear shocks
10. Goodyear Wrangler Duratrac 285 75 16 (33") "E" tires
11. OEM early-edition "Off Road" 6-spoke wheels
12. 2 degree axle shims
13. Rear diff breather mod
14: BORA 1.5" wheel spacers front and rear (front fenders slightly trimmed)
Exterior/Armor/Recovery:1. Hefty Fabworks aluminum front bumper and aluminum radiator skid plate
2. Smittybilt X20 10K waterproof winch with Masterpull 3/8" synthetic line and G110 hook
3. Bucksnort non-tire carrier rear bumper
4. Hefty Fabworks engine, transmission, transfer case and fuel tank skids
5. Shrockworks rock sliders
6. BTF M226 rear diff cover
7. Insain Fab aluminum full replacement roof rack w/ Gobi tool box and Baja Racks hi-lift mount
8. 60" Hi-lift extreme jack
9. ARB 2000 shade awning mounted to driver's side
10. (X2) Two gallon Rotopax fuel cans mounted to IF roof rack
11. OBA setup consisting of ARB twin compressor and quick disconnect fittings plumbed into the front and rear bumpers
12. Vigg Designs vinyl hood blackout
13. Blacked-out grill
14. Gobi passenger-side rear ladder
Lighting:1. 40" single-row LED light bar
2. 7" side-facing "alley" lights mounted above driver and passenger side front doors
3. Pair of 7" rear-facing LED lights (spot beam) mounted to rear roof on custom made lightbar mount
4. Pair of flush mount cube-style LED lights (flood beam) mounted in rear corner plastics, activated by 3-way switch that allows for operation with or without reverse lights
5. Full array of amber strobe/LED warning lights, including:
a. Pair of rear-facing Whelen LINZ6 strobes mounted to rear roof on custom made lightbar mount
b. Pair of Whelen Vertex hideaway strobe lights mounted inside rear reverse lights, synced up to rear-facing LINZ6 lights
c. Total of 4 SVP Signal "Mini Phantom Max" LED lights mounted inside rear hatch window and rear side windows
d. Pair of front-facing Whelen LINZ6 strobe lights hidden behind the grill
e. Forward-facing SVP Signal "Mini Phanton Starburst" alternating LED light in windshield (mounted to rear view mirror)
6. Whelen TIR3 red LED light mounted to rear roof on custom made lightbar mount - operates as external 3rd (4th?) brake light
7. All interior lighting converted to LED bulbs
8. HID headlight retrofit with Mini H1 projectors
9. 20" Rough Country single row LED light bar mounted to top of front bumper
Electrical/Electronics/Communications:1. Isolated dual battery setup with Northstar group 34 deep cycle primary battery (under the hood) and Optima Yellow Top aux battery (under the driver's seat)
2. Fully isolated auxillary distribution circuit with Bussman 10 circuit fuse/relay box installed behind glove compartment
3. Waterproof 6-circuit terminal box mounted to bottom of roof rack (to simplify addition/removal/replacement of roof-mounted lighting)
4. 1000W inverter hard wired under front passenger seat
5. In-dash dual port USB charger mounted below factory 12V plug
6. Sony 6" in-dash radio w/ integrated TomTom navigation
7. XM Onyx2 satellite radio
8. Google Nexus 7 7" tablet mounted with RAM bracket on lower right dash (for trail maps, weather info, etc.)
9. Yaesu FT7800 dual band mobile ham radio
a. Radio body mounted under passenger seat with control/face mounted to upper center console just below dash
b. External speaker mounted inside void space under center console, just left of the gear selector
c. Dual Band Diamond antenna mounted to passenger side of rear hatch
10. Uniden Pro520XL CB
a. Radio body mounted inside center console
b. 48" Firestik fiberglass antenna mounted to vehicle body near driver side tail light
11. Carling Contura V illuminated rocker switches from OTRATTW
Appearance/Interior/Convenience/Extras:1. ARB 50 quart fridge with mounting kit. Fridge attaches to folded-down 40" rear seat and is hard-wired to aux battery
2. Gentex rear-view mirror with compass and exterior temperature sensor (with green display)
3. Dual USB charging terminal installed in the empty 12V outlet slot in the dash
4. 5 switch dash panel from leather/heated seat Frontier PRO4X model
5. Late-model Pro 4X overhead sunglasses holder/bluetooth mic console (also contains custom-installed 4 switch panel)
6. Front and rear seats swapped out for older "S" model seats with mesh sides/backs and side map pocket
7: Offroad Gorilla "hood rod mod" with gas struts
8: Weather Tech front floor mats
9: Fully tinted windows (20% rear, 35% front)
10: Stealth rear factory badges (plasti-dip)
11: Rear corner plastics coated with "Forever Black" plastic dye
12: 150# hatch strut mod (McMaster Carr version)
PHOTOS How she sits today:
Joe's Xterra
Joe's Xterra
Joe's Xterra
Joe's Xterra
Joe's Xterra
Joe's Xterra
Joe's Xterra
Joe's Xterra
Joe's Xterra
