New Hefty aluminum front bumper has been installed, but there is still much work to be done. Here's what I managed to accomplish so far:
Removed the old front bumper and quickly found it a new loving home:
Joe's Xterra
I rolled around for about a week with no bumper cover (just the OEM metal bumper re-installed, for protection). I was actually starting to dig the aggressive look
Joe's Xterra
Finally had a chance to work on it more on Friday. Got my winch installed in the bumper during the day. This took much longer than expected, as I ran into some issues clocking the gearbox of the winch (the clutch lever wouldn't have fit without clocking it). The gearbox basically fell apart when I tried to clock it, and I had to put it all back together. What a horribly messy and unpleasant job. Once mounted up, I was excited that there was enough room to fit the solenoid box inside the bumper next to the winch. Note that the solenoid boxes on these X2O winches are advertised as being IP68 rated, along with the winch itself. It wedged perfectly between the edge of the bumper and motor housing:
Joe's Xterra
New bumper brackets mounted up to the frame. The setup still uses the steel hefty brackets (only the bumper and rad skid are aluminum):
Joe's Xterra
The bumper is SUPER light... the whole setup with the brackets, rad skid and bumper itself is like 65 lbs. But once the winch is mounted, it's still a bit too much for one person to do without a little assistance. Thankfully, it was light enough to jockey into position and I used a floor jack to help with the rest:
Joe's Xterra
All mounted up. I love how it looks:
Joe's Xterra
Joe's Xterra
What's next: I still need to mount my fog lights. The Calmini bumper held the fog light assemblies with their four bolts that attach them to the round mounting bracket that fits on the OEM bumper. Unfortunately, I discarded the round brackets when I got rid of my OEM bumper, so I'm stuck having to buy new brackets or maybe even new fog light assemblies. If I can't get my hands on a set of brackets from a junk yard or something, then I may just buy a set of cheap aftermarket "OEM style" lights and use only the brackets. I can get a set for $45 or so on eBay.
I also need to work on a way to mount my ARB twin air compressor behind the grill. I have blinky lights back there that may be in the way and may need to be relocated (I already relocated my Hella horn when I mounted the bumper). I'll have to fab up some kind of bracket to hold it in place, so plenty of internet research (mostly reviewing photographs) awaits me...
Finally, I will be painting my grill. You can probably see in the images that the bottom is scuffed up to hell from the cover I had over the winch with my old bumper. I plan to paint it black and probably install some mesh in place of the factory plastic honeycomb, but I'm still thinking about that one.
