Author Topic: anyone rocking SPC UCA?  (Read 6137 times)
3rdhandedX
    • 05 X
« on: February 14, 2015, 02:02:01 PM »
I have strut spacers and rest are stock. my question is can I just install titan UCA and do an alignment?
or if I do choose on titan uca..I have to use uca and lca together order to work ..
I just want to mininize / have some more clearance on top of coil bucket cheapest possible
2nd questio .. for those with SPC UCA
how does alignment holding up on you guys?  I don't do heavy wheeling . does the alignment nut moves around on you guys?  I'm thinking about getting these over rough country uca
« Last Edit: February 16, 2015, 04:09:15 PM by 3rdhandedX »
« Reply #1 on: February 14, 2015, 02:29:19 PM »
You can't mix titan UCA with Xterra LCA.
Titan UCA has to be used with titan LCA.  Stock titan UCA still suffer from coil bucket contact.
3rdhandedX
    • 05 X
Re: can this work?
« Reply #2 on: February 14, 2015, 03:31:12 PM »
I see. thank you
Motorpig77
  • 4wd Pts: 31
Re: anyone rocking SPC UCA?
« Reply #3 on: February 19, 2015, 12:41:58 AM »
I ran the SPC UCA's before I swapped and had no alignment issues.  They Nut stayed in place without an issue.  The only issue I had with the SPC's was the ball joints...but that was my own fault! The boots tear easily! :)
« Reply #4 on: February 19, 2015, 09:17:58 AM »
I think the boot issue is poor design on spc's part.  To align the truck properly the ball joint has to be pushed all the way in and this makes it contact the coilbucket, ripping the boot.  I think everyone that has run spc has figured this out at some point and had to grind down the lip on the coilbucket to stop ripping the boot.
« Reply #5 on: February 19, 2015, 11:06:57 AM »
Or where clueless, but fortunate enough to have people who knew better from the start!
http://imagizer.imageshack.us/v2/800x600q90/18/op72.jpg
3rdhandedX
    • 05 X
« Reply #6 on: February 20, 2015, 07:42:40 PM »
I will definitely grind some rubbing area down . thanks for this info !
« Reply #7 on: February 21, 2015, 12:13:19 PM »
The shirt says it all.
Sent from Planet Claire
 using Tapatalk
Duke562(rmaligie)
« Reply #8 on: February 21, 2015, 08:08:37 PM »
John, I just put those on my 4runner so far no issues
