I'm currently running a poor man lift with a spacer up front and shackle in the rear. I also have adjustable Billstein 5100s with the fronts adjusted to 1/2" above stock height (one notch on the shock) to preload the front springs just a tad and compensate for the weight of the winch.
The rear end sits just a little too low for my liking. I'm about 2.5-2.75" above stock height in the front, and maybe 1.5" or so above stock height in the rear. She sits pretty level right now, but I want to restore a tiny bit of rake to help with the gas mileage.
Rather than installing an even taller shackle, I've decided that an Add-A-Leaf is the way to go, which will also stiffen up the rear end just a tiny bit, so it doesn't sag as bad under a load. I've seen the damage caused by the tiny AAL springs (cracked leafs, etc), so I shopped carefully and acquired a Calmini AAL from another user here on the forum. I've always been a fan of this particular setup, because the long springs distribute the weight over the whole current leaf and don't make the ride as harsh or put too much pressure on a single point.
Now I'm down to the questions - for starters, I'm wondring if I should install just one of the leafs per side, or both. The package comes with a long leaf and a shorter leaf. The calmini website says the full package will add roughly 1.5" of height, which is more than I'm looking to get here. I would like to add about .75 or 1 inch total (insert rimshot or "that's what she said" comment here). I could install just one of the two springs per side, or I could install both and remove the factory overload spring. Does anyone have an opinion on any of these options, and if I do install just one of the two, should I go with the longer one higher up in the pack or the shorter one lower down in the pack?
Second - I need some harware to make it all happen. I don't have much experience dealing with leaf springs, especially adding springs to the existing pack. The u-bolts are pretty self explanitory, and I've already found the info I need regarding specs on those. The questions that reamin are:
1) Do I need a pinion angle shim for the axle? I'm only looking to add 1 inch of lift maximum from the additional spring(s), but remember that I already have about 1.5" in the rear from a shackle.
2) Can I reuse the factory center-bolt for the leaf pack, or do I need to replace this (and if I need to replace, what are the specs I need to buy)?
3) How do I remove the existing "clamps" that are keeping the springs alligned toward the ends - I searched and searched both this formum and thenewx for a how-to in regards to adding a leaf, but came up short
4) What should I replace the "clamps" that are keeping the springs alligned with? Some people have mentioned just bolting a couple of steel plates together around the springs - is this ok, or is there a better solution?
5) The factory springs seem to have a small plastic shim installed between each one. I presume this is to prevent the aweful metal on metal squeeking that would occur when the springs flex. The Calmini springs don't have anything like that installed on them - should I try to insert some tiny plastic to shim it out and keep it from squeeking?
Thanks for all of the help everyone!
