Author Topic: RikRong's BluX build...Sshhiinnyyy....  (Read 158548 times)
Re: RikRong's BluX build...GONE to Moab May 2019
« Reply #120 on: May 08, 2017, 11:35:15 AM »
Had some fun in Hollister Hills this weekend...
« Last Edit: July 18, 2017, 12:53:37 PM by RikRong »
« Reply #121 on: May 08, 2017, 12:40:49 PM »
I especially liked the KIA recovery shot over on FB.
Nice looking campground.
« Reply #122 on: May 08, 2017, 03:05:11 PM »
The Kia was turning heads all weekend.
« Reply #123 on: May 21, 2017, 08:21:57 PM »
Installed PRG heimed tie rods yesterday.  The steering feels just slightly tighter, but nothing huge to report. I got the opportunity to perform my own alignment at the auto hobby shop and I'll say it was pretty awesome.
« Reply #124 on: May 22, 2017, 10:13:58 AM »
Did you have to drill through your knuckle? Or did they give you a taper insert?
« Reply #125 on: May 22, 2017, 10:16:36 AM »
No drilling, the pillow is tapered.
« Reply #126 on: June 10, 2017, 10:58:17 AM »
Installed steelies today.
Riz98
  • 4wd Pts: 8
  • PBR ASAP
    • 2002 Nissan Xterra
« Reply #127 on: June 11, 2017, 12:29:39 AM »
Looks good.  Why the switch from alloy to steel?  Just curious as I will be going the other way around from steel to alloy to try and loose some weight as the 3.3 is slow.
« Reply #128 on: June 11, 2017, 06:59:25 AM »
 If you ding up an alloy wheel you can't hammer it back into place to accept the bead. The wheel is essentially ruined. With a steel wheel and a BFH you can reshape them in the field. RikRong may have a different reason though for his decision.
« Reply #129 on: June 11, 2017, 10:10:22 AM »
Really, I just wanted to change up the look a little, but Celt does have a good point. The wheels I took off all have dings that would never be repairable.
« Reply #130 on: June 11, 2017, 10:43:19 AM »
You can repair them, they do have professional wheel repair. I had one wheel that had a repair. The PITA thing is getting it balance. They had to use so much weight, rim weight and sticky weight.
Rick black wheels and a blue lock ring would like super clean on your X.
« Reply #131 on: June 11, 2017, 11:57:49 AM »
Hey rick, have you considered the american racing steel wheel?
http://www.americanracing.com/wheel/8848/ar767
« Reply #132 on: June 11, 2017, 01:15:38 PM »
I might have to get them repaired so I can sell them.
I have but it doesn't​ look like they have the right hub spacing. You're in luck for your first gen, though.
« Last Edit: June 14, 2017, 08:47:43 AM by RikRong »
Riz98
  • 4wd Pts: 8
  • PBR ASAP
« Reply #133 on: June 14, 2017, 03:09:58 AM »
Yeah wheels are a easy way to change up the look of a vehicle.  They look good on there.  A couple of my steel wheels have a slight bend to them and take a lot of weight to balance out.  Im hoping the alloys will stay nice and straight getting rid of the small vibrations I get on the highway.
« Reply #134 on: June 14, 2017, 10:32:09 AM »
Steelies look great Rick.  8)
