Author Topic: RikRong's BluX build...Sshhiinnyyy....  (Read 320023 times)
lutsie
Re: RikRong's BluX build...GONE to Moab May 2019
« Reply #90 on: September 04, 2016, 01:38:21 PM »
What are the updated measurements?
« Reply #91 on: September 04, 2016, 03:11:58 PM »
I think we measured it at about 39" right after the install, that's about 2" higher than it was before.  However, it has settled quite a bit, so I'm going to measure again when I get back home tomorrow.
lutsie
« Reply #92 on: September 04, 2016, 05:18:12 PM »
Awesome.
GreenAcres
  • 4wd Pts: 9
    • 2007 XTerra Off Road
« Reply #93 on: September 04, 2016, 06:06:42 PM »
Looks fantastic!  Amazing to see you guys pull of such a significant mod so quickly and with such a good outcome! Well done.
SyK0
    • 2012 Xterra S
« Reply #94 on: September 04, 2016, 08:59:24 PM »
Looks great! Hope to see it in person in the next SCC or SCXF meet  8)
What were your fender to ground measurements before the swap??
lutsie
« Reply #95 on: September 04, 2016, 09:41:57 PM »
He listed in post 82. Been following intently I'm thinking of going this route
« Reply #96 on: September 05, 2016, 08:05:39 AM »
Yeah, check out that post, I can't remember exactly where I was at. I will post updated specs when I get home.
« Reply #97 on: September 05, 2016, 07:45:27 PM »
Well, here's the good stuff...
First off, deduct .5" off the measurements I posted in post #82. I measured with the tape straight today. With it bent, the measurements were off about .5". Anyway, new height is 38.25" from fender to ground, front and rear. 23.5" from fender to hub, front and rear.
« Last Edit: July 18, 2017, 12:52:43 PM by RikRong »
« Reply #98 on: September 05, 2016, 08:36:05 PM »
Rock "N" Roll Buddy  >:D
« Reply #99 on: September 05, 2016, 09:59:28 PM »
Sexy as F!
Kjswa
  • 4wd Pts: 10
    • 2006 Xterra Off Road manual
« Reply #100 on: September 08, 2016, 11:15:33 AM »
Looks killer!! You've got yourself a great rig! Only 4 hours? I helped a friend replace the ball joints and coil-overs on his '96 Tacoma took three of us 2 days. Haha
« Reply #101 on: September 08, 2016, 12:01:01 PM »
Well, it was little over 4, to be fair.  haha  I was on one side, Toro was on the other. Woody and OccupantX plugged away on the skids and then the diff, while we were working on the suspension.  It was a pretty good team.
SyK0
    • 2012 Xterra S
« Reply #102 on: September 14, 2016, 03:10:31 PM »
Looks awesome man! Saw the pics on IG first.
Did you have your front sway bar on before the swap??
« Reply #103 on: September 14, 2016, 03:16:12 PM »
Thank-you.  The truck is a little bit of an IG whore.   lol
I did have the sway bar installed prior.  At this point, I wish I had removed it a long time ago.
SyK0
    • 2012 Xterra S
« Reply #104 on: September 14, 2016, 05:57:52 PM »
Haha, mine has taken over my page too.
Ahhh, dang.  I was hoping you had it off before to see how much of a difference it was with your aftermarket suspension vs. titan swap. I was thinking most guys say its a huge difference because most run sway bars and then with a titan swap they don't have one for the first time. No front sway really is a huge difference.
