Author Topic: Puma compressor question  (Read 6393 times)
« on: May 20, 2015, 02:54:44 PM »
For those of you that have a Puma 12v compressor (knightrider, 0317, anyone else?) -
I've decided to make this purchase. As you may remember, I ran an OBA setup using a harbor freight compressor recently. Well, the HF compressor died on the second trip I used it on. The good news is, I got it replaced free under warranty. But I don't want to mount it back up and have it break again, leaving me stranded on the trail.
So I've decided to buy one of these Puma units, as they seem like a good, rugged and durable unit that gives good CFM performance for the price. I can't quite justify the $500+ on the ARB twin unit to the wife.
Anyway, I have an opportunity to buy the pump unit with no tank for $229, or I can get the 1.5 gallon unit for less than $10 more. It seems like a no brainer to get the tanked unit, but I want to mount the compressor under the hood in front of the stock air box where my HF one was. My question is - can the pressure switch, regulator and tank be removed so that I can mount the pump behind the air box and use these items elsewhere within the setup? I can't find any good close-up photos of the way it's all attached to see if it can come off and be used.
Thanks in advance!
« Reply #1 on: May 20, 2015, 03:46:13 PM »
Yes the pump can be "divorced" from the tank, but after doing this myself, I wouldn't bother.  If you want to run it as is, get the one with the tank, if you want a remote tank, go ahead and just buy the pump and the rest of the parts separately.
I actually don't use the puma anymore so its sitting on my shelf in the garage, I still have the tank and relay and such, I can give you a deal if your interested.
Re: Puma compressor question
« Reply #2 on: May 20, 2015, 04:29:17 PM »
Very interested. Let's work something out. Are you coming to the food truck event tomorrow evening? Shoot me an email or text and we'll work out a price.
« Reply #3 on: May 20, 2015, 08:31:45 PM »
My set up is in the rear cargo and I do not recommend puma, I have had nothing but electrical problems and blown fuses. Every time I use the unit I cross my fingers and hope for the best. Maybe if you wire yours under your hood, you will have better luck.
« Reply #4 on: May 20, 2015, 09:55:27 PM »
I just throw mine in the dodge when I need to use it. I wired alligator clamps to the leads. Take it out when I don't need it. With the tank it's very bulky.
