Author Topic: Yaesu FT-8900R  (Read 13312 times)
« Reply #15 on: September 23, 2015, 09:29:20 PM »
I would not mount a ham radio in the center console, they are much more power(heat) hungry than a CB radio and need fresh air, hence the fan.  There is lots o space under the passenger seat, 4 bolts and a few plugs to remove.
Sent from my XT1095 using Tapatalk
« Last Edit: September 23, 2015, 11:48:17 PM by knightrider »
PainRoller
  • 4wd Pts: 46
  • DILLIGAF
Re: Yaesu FT-8900R
« Reply #16 on: September 23, 2015, 11:22:16 PM »
Thanks for all the input Guys!  It really helps!  ;D
Knightrider -  we plan to run the Ham power and ground directly to the battery.  But can we run it thru the BlueSea in the cabin instead? Inquiring minds want to know..
Re: Yaesu FT-8900R
« Reply #17 on: September 23, 2015, 11:47:41 PM »
of course you can, just make sure you have the proper size fuse, whatever the radio came with is the proper size :)
Re: Yaesu FT-8900R
« Reply #18 on: September 24, 2015, 12:11:34 AM »
Fuzes,,,,,, we don't need no stinking fuzes...................
All foolin around aside, PR is going to have a pretty nice setup in the end I'm thinkin.
PainRoller
  • 4wd Pts: 46
  • DILLIGAF
Re: Yaesu FT-8900R
« Reply #19 on: September 24, 2015, 01:18:06 AM »
SWEET cherry pie!  This will make zee Boss very happy!  ;D
PainRoller
  • 4wd Pts: 46
  • DILLIGAF
Re: Yaesu FT-8900R
« Reply #20 on: September 24, 2015, 05:57:06 PM »
I KNEW I wasn't completely crazy!!!
Pauls setup:
http://i6.photobucket.com/albums/y215/paul1960/Xterra/Ham%20Radio/HamRadioMounting.jpg
Yaesu FT-8900R
Here's what's under our passenger seat:
More specifically:
Any ideas as to what this is and can we just rip it out?  ???
Edit:  I think someone blew chunks in this vehicle at one point.... :-X
2nd Edit:  I think this has to do with our suckin' Bluetooth.....  guess it's going in the middle console.... ::)
« Last Edit: September 24, 2015, 06:01:45 PM by PainRoller »
« Reply #21 on: September 24, 2015, 06:20:01 PM »
I will have to get pics of mine, I believe I mounted it to the rear of the amp.
PainRoller
  • 4wd Pts: 46
  • DILLIGAF
« Reply #22 on: September 24, 2015, 07:18:19 PM »
Yeah, Danny/Toro talked us off the "crazy" ledge.  I think we are mounting it in the same spot.  Kinda worried about passenger in back kicking it tho.
« Reply #23 on: September 24, 2015, 07:34:59 PM »
Yea I worried about that, then I realized I never have the rear seats up, let alone have the seat bottoms in the xterra.
It's honestly not that bad, I would flip it so the antenna connection is towards the front, and the power is towards the rear, then even if someone does kick it, they won't hurt nothing but their toe.
PainRoller
  • 4wd Pts: 46
  • DILLIGAF
« Reply #24 on: September 24, 2015, 08:27:33 PM »
Haha!  Yeah, our back seats aren't seeing much action!  And we did flip it as you described.  Thanks!!  ;D
Re: Yaesu FT-8900R
« Reply #25 on: September 24, 2015, 09:24:46 PM »
I might not be the most techie savvy guy around here, I'll concede to that. In my opinion keeping things simple is the way to go. Something I learned in the Military because when things break down it takes just that much more effort to get everything back up and running. The radio systems I've installed and had help installing are basic and I like to keep them that way. I also have a back up to those systems which is a handheld and a way to keep it up and running. Lots of really great info here on these boards with some super knowledgeable folks!
Re: Re:
« Reply #26 on: September 24, 2015, 09:38:03 PM »
.....Yeah, our back seats aren't seeing much action......
My condolences.
PainRoller
  • 4wd Pts: 46
  • DILLIGAF
Re: Re:
« Reply #27 on: September 24, 2015, 10:43:53 PM »
Re: Re:
« Reply #28 on: September 25, 2015, 08:46:43 AM »
Dood...
Just wait til' you delete a thread... ;)
Re: Re:
« Reply #29 on: September 25, 2015, 09:15:26 AM »
An Xcursion thread....24 hours before the actual event.....
