OBA Update:
Well, crap......crap, crap, crap........CRAP!! OBA FAILED on "Randy's Most Excellent Run".
Thanks Randy for getting us back up to pavement pressure.
Failure resulted from heat related hose blowery.
As a result, FiG bought/installed new, improved high temp hose and a couple of Brass Ball Check Valves.
But because we have been known to OR solo, we didn't want to risk further failures. So FiG put the OBA thru its paces on a nice warm day (well over 100 degrees) to ensure no further failures due to temperature issues. And guess what? Both air compressors DIED. I just don't think those air compressors were up to the task, nor were they capable of sustained use - especially in a hot engine compartment.
So we move forward with OBA phase 2 (aka the high percentage play) :
ARB CKMTA12 '12V' On-Board Twin High Performance Air Compressor (I think both Danny and Joe are running with this unit?)
After much discussion, we've decided to install this unit in the rear cargo (passenger panel). Reasoning: Less dust, no engine heat, no water crossing issues, better air circulation. Pretty much here, but positioned a little differently.... (this is an example, not our rig. In fact, it's Danny's rig
Will post updates, with pics, when unit installed......
