Author Topic: Ok just ordered a Baofeng hand held ham radio  (Read 9642 times)
fiercextreme
  • 4wd Pts: -10
    • 2015 xTERRA OVERLANDER MODEL!
« on: November 23, 2015, 08:27:30 PM »
Ok just ordered a Baofeng hand held ham radio.
http://www.amazon.com/BestFace%C2%AE-UV5R-Handheld-400-480Mhz-Transceiver/dp/B00YU3QMEG/ref=sr_1_39?s=electronics&ie=UTF8&qid=1448338971&sr=1-39&keywords=ham+hand+held
do I need to do anything to program it or what not? I see theres a cd and cable, u can buy separate, to run to ur laptop for some type of programming.
WARNING: P&P crossing a-head
Re: Ok just ordered a Baofeng hand held ham radio
« Reply #1 on: November 23, 2015, 09:26:24 PM »
Buy this
Download Chirp
Do not transmit until you have your license.
Enjoy.
« Reply #2 on: November 24, 2015, 12:44:38 AM »
You can program the radio without the programming CD. I would recommend that you at least learn how to program it yourself. The programming CD's make life a lot easier for you if you are trying to download multiple frequency banks but the downside is you won't learn your radio as well as you probably should. If you don't want to order the programming CD as SteveC recommended downloading CHIRP onto your computer, it's free programming software that's compatible with those Baofeng radios. Another thing to think about is investing in a solid antenna. Without an antenna you will be at the mercy of your rubber duck that comes with the radio. They are decent if you are up high and out of a vehicle. A good antenna will get you out there by leaps and bounds drastically increasing your transmit/receive range and clarity. They make plenty of them that are compatible right out of the box for a radio like you bought there. Check and see if they are supplying you with an additional 2AA or similar battery box. Since it's a handheld you will need a way of keeping the battery charged, which means having an inverter or an extra battery pack. The last I would suggest is downloading RepeaterBook onto your phone and computer. You can use that to find all the repeaters in a given area you plan to travel in. In my opinion it's an invaluable item to have along with your radio system.
« Reply #3 on: November 24, 2015, 11:50:49 AM »
Just to let everyone know Baofeng has just come out with an 8watt  transceiver = 60% more power for I believe ~$50.   Very good buy.
And to all of you.   You can listen to a Ham and in emergency situations can transmit on a Ham without a license.   But hey for a few hours of free study and $15 you can be a "Ham too".
« Reply #4 on: November 24, 2015, 07:57:08 PM »
I also just got one of those. I also ordered everything I needed to make it a basic mobile transceiver. Then, I started reading and reading and realized I wanted something with far more capability, and I ordered a Yaesu FT-7900R. Ha-ha I'll be programming the BaoFeng to mirror my Yaesu for trail runs though. Now, here's to hoping I pass my test next weekend.
« Reply #5 on: November 24, 2015, 08:12:14 PM »
Easy Peasy.  No problem with the test.
fiercextreme
  • 4wd Pts: -10
« Reply #6 on: November 25, 2015, 08:27:54 AM »
After I'm pro hammer I'll up my game. This is to just get by w/out being totally in dark. I think price is great and with a 3800 mah lithium battery I prolly won't need charge that much. I see an aftermarket 15" antenna if I decide. I also ordered the $3 cd. Thx 4 info on repeaters. I'll load the app.
« Reply #7 on: November 25, 2015, 11:32:31 AM »
Terry we all know you are a "Ham"!!...       :) :)......:) :)
« Reply #8 on: November 25, 2015, 08:00:03 PM »
This is true.    :o
But more options available:
http://www.hamradio.com/?utm_source=streamsend&utm_medium=email&utm_content=25423105&utm_campaign=Pre-Sale112515
Especially the FT2900.   Great little radio.
ShockBlue_Scott
    • 2002 Xterra
« Reply #9 on: March 04, 2016, 06:17:49 AM »
How do you like your Baofeng? I ordered one as well. One of the groups I am part of uses them as a form of communications at a ranch that we patrol on the border and its nice having another form of communication if something happens to the car or during wheeling...
Scott
2002 Nissan Xterra Shock Blue
City Heights, San Diego CA
fiercextreme
  • 4wd Pts: -10
« Reply #10 on: April 07, 2016, 01:43:12 PM »
Ok I just took it out of the box and I am charging it now. I'll be installing my cb radio in a few days also. What channel does the Xterra club run on?
« Reply #11 on: April 07, 2016, 03:08:02 PM »
SCCX uses 146.535 on simplex, for the life of me I can't find the FRS or CB channels.  I know they're in a thread somewhere, but I can't dig it up.
SCCX backups (thanks to Sage Bromax for throwing this together):
2   Convoy   Backup Trail Frequency A   146.4750   none   146.4750   none   Fallback channel in case above channel is too busy
3   Convoy   Backup Trail Frequency B   146.4900   none   146.4900   none   Fallback channel in case above channels are too busy
4   Convoy   Backup Trail Frequency C   147.4800   none   147.4800   none   Fallback channel in case above channels are too busy
5   Convoy   Backup Trail Frequency D   146.5500   none   146.5500   none   Fallback channel in case above channels are too busy
« Reply #12 on: April 07, 2016, 07:13:34 PM »
CB channel depends on the month of the run, the phase of the moon and the disposition of the trail leaders significant other.   In other words, it changes.
Sent from my RTT while stargazing
« Reply #13 on: April 08, 2016, 09:29:16 AM »
CB channel also varies depending on whether or not you know how to use a shovel. Basically, stay away from channel 8.  O0
« Reply #14 on: April 08, 2016, 09:45:48 AM »
HAHAHHAHAHAHHAHHAHA............. Man, I just knew that day was going to get lots of mileage!
