Author Topic: **The >APRIL< Mojave Road 2016 Food Thread**  (Read 56835 times)
Re: **The >APRIL< Mojave Road 2016 Food Thread**
« Reply #105 on: April 17, 2016, 09:16:33 PM »
« Reply #106 on: April 17, 2016, 09:34:31 PM »
With that many granola bars you'd better have a big shovel. :o
He has one and he's "Not afraid to use it"
Ba-Zing!  O0
Ga!!!  :D :D :D
http://imagizer.imageshack.us/v2/1024x768q90/923/vsUI5n.png
Re: **The &gt;APRIL&lt; Mojave Road 2016 Food Thread**
« Reply #107 on: April 18, 2016, 06:53:07 AM »
Because 22 red arrows would have been overkill...
« Reply #108 on: April 18, 2016, 08:53:19 AM »
Thanks now you got me counting red arrows
« Reply #109 on: April 18, 2016, 11:45:26 AM »
Christiaan, I want to apologize on behalf of the members for this immature and senseless thread jack.
BTW, I live in the avocado capital of the world.
« Reply #110 on: April 18, 2016, 12:03:20 PM »
 Is anyone makin name tags for this trip?
« Reply #111 on: April 18, 2016, 01:30:42 PM »
Ok guys....we're getting very close to the event, and I think just about everything has been covered...
2 things came to mind this morning
-Coffee....please speak up if you plan on making coffee, and if it is possible to make coffee for the masses
-a bbq/grill  We need one medium sized one for a few tri-tips on Saturday
Thanks,
-Christiaan
« Reply #112 on: April 18, 2016, 01:39:48 PM »
Thanks,
-Christiaan
Coffee, I can't live without it.  When it comes to camping, instant does just fine for me.  I have a backpacking stove I'm going to use for coffee in the mornings, but I was only planning on making enough for the wife and myself.  That little stove can boil water in about 2.5 minutes or less, so I can provide hot water for the masses.  However, I don't have anything for actual brewing, I was just planning on instant coffee.
edit:  What I meant to say was if someone has a percolator or a method of boiling large amounts of water, I can provide the flame and fuel.  If no one really has the capability to percolate, I can get a larger can of instant coffee and provide that, along with hot water from the kettle that's in my cooking kit.
« Last Edit: April 18, 2016, 02:12:20 PM by RikRong »
SCUBA_Dale
  • 4wd Pts: 39
    • 2015 Xterra Pro-4x
« Reply #113 on: April 18, 2016, 02:41:21 PM »
I have a percolator that I use for boiling water...lost the percolating stuff a long time ago.  I also am just fine with instant, which I planned on bringing.
« Reply #114 on: April 18, 2016, 03:23:27 PM »
I just realized I have a press that I'm going to bring; I have ZERO idea how to use it...but a little taco told me it makes good coffee!!!
« Reply #115 on: April 18, 2016, 03:28:06 PM »
The best coffee I've ever had was brewed in a siphon coffee maker, the second best was made in a press.  Long story, short, presses make dang good brew.
« Reply #116 on: April 18, 2016, 03:42:33 PM »
I have zero idea how to use it, but it seems like a pretty simple process; I'm going to bring a small can of grounds, and some cream, and learn on the fly!!!
« Reply #117 on: April 18, 2016, 03:51:26 PM »
I will bring my BBQ attachment for my camp chef grill. The cooking surface is 16" deep x 24" wide x 8" tall, which should be good for a few tri-tips. My only concern would be making sure the lid will close, but I suppose we can cut the tri tips down if we have to.
Also, propane might be a concern. I'm only bring a 10lb tank, and I'm not even sure how full it is (I think we used 1/4 - 1/2 of it in Death Valley). I'm confident there's enough to cook the 8 lbs of bacon on Saturday morning, but cooking three large tri-tips could use a lot of propane and I'm not confident that there's enough in that tank for both tasks. Will there be some back-up propane just in case?
« Reply #118 on: April 18, 2016, 03:57:16 PM »
Thanks for the help Joe; are you referring to the white propane tanks?  Can someone else step up and bring one as back-up?
« Reply #119 on: April 18, 2016, 04:12:41 PM »
Yes, it uses full-size propane tanks. So a 10 lb or a standard 20 lb bbq tank would work. I have a couple 20 lb tanks at home, but I simply won't have the room for one by the time I bring the grill, griddle and bbq attachment, plus my camping gear.
I have an adapter to use the small green cans in an emergency, but this grill is a beast and can really go through propane if being used to capacity. I only got about 8 mins of use from all three burners on a brand new full green can. Depending on how long those tri-tips need to cook and how hot, someone would have to be swapping out green cans quite a few times. :)
I'll search for a place around my house where I can top off my 10 lb tank too. The feed store I use has changed their policy and charges a 5 gallon minimum now. That sucks when you need to top off a 2.5 gallon tank that's less than half empty.
