Author Topic: Antenna mounting question for ham AND CB radios  (Read 15275 times)
Spectre
    • 2007 Xterra
Re: Antenna mounting question for ham AND CB radios
« Reply #30 on: February 28, 2016, 05:34:37 PM »
Or
Sent from my SAMSUNG-SM-N910A using Tapatalk
W6VIC
2007 Stock "for now" Xterra
If you can't stand the heat, then stay out of my crease.
« Reply #31 on: February 29, 2016, 10:01:01 AM »
Those are both cool spots. I personally like the look of the driver side better - it's an otherwise wasted space (and I LOVE taking advantage of otherwise wasted spaces), and is within your view but doesn't block your line of sight like the center location does. BUT, I use my mic with my right hand while driving and that would be a bad spot because the mic cable would run across the steering wheel and interfere with your other hand operating the vehicle, so I'd probably end up mounting it above the center of the dash instead. If you're a lefty and use the mic with your left hand, I'd say driver side.
Spectre
    • 2007 Xterra
« Reply #32 on: February 29, 2016, 10:51:48 AM »
I think I'll put it on the drivers side. I usually drive with my right hand. Also I write and play hockey right handed but everything else I do left handed. I'm kinda weird like that
W6VIC
