Author Topic: Xrod's unnamed t-swap  (Read 14957 times)
Xrod
    • 2007 Nissan Xterra x
« on: March 20, 2016, 09:08:57 PM »
So... First things first!
Username:  Xrod
Real Name: Rod
Year:  2007
Make:  Nissan
Model: Xterra
Trim: x
Color: red...ish
Mods: Titan swapped suspension
         Prg aal and shackles
         Blacked out plastics
         265/75-16 Hercules at2
         Prg t-swap extended axles
         2" hub centric wheel spacers (rear)
     Removed:
          Sway bar
          Mud flaps
« Last Edit: July 07, 2016, 08:10:59 AM by Xrod »
This ain't my first rodeo!
Xrod
Re: Xrod's unnamed t-swap (in progress)
« Reply #1 on: March 20, 2016, 09:46:26 PM »
To start off let me explain that the process of sourcing and pricing my swap has been both a fun and educational process. I think I have put together quite the practical and budget minded system. The way I figure I should end up with about 4" of lift all the way around with way-better-than-stock travel. Please let me know if I am missing anything or if you have any tips that could help.
In hand:
      dorman oem Titan uca's and lca's
      Struttek oem tundra coilovers (changing to x tophat)
      Prg tie rod extensions
      Prg braided extended front brake lines
      Prg adjustable shackles, 3deg shim, bilstein rear shocks, dual AAL (PRG Deluxe rear kit)
Awaiting delivery:
      Prg t-swap extended cv shafts
      Rear brake line 90 degree bracket
That being said, delivered, I am into this mod $1400 so we will see what that turns out.
Also I am debating what size tire to go with going to stick with stock 16" rims for now so... at's are a must but do I go 32...33...?
« Last Edit: March 20, 2016, 09:53:08 PM by Xrod »
« Reply #2 on: March 21, 2016, 07:23:37 AM »
Hey dude,
   Welcome to the forum. One of the things we do here is help each other out and share information.
   I'd like you to research the choice of using OEM UCA's for your build. Although cost effective, you will not be able to align your front end.
    That said.....anything less than 33's will look goofy running a 4" lift.
« Reply #3 on: March 21, 2016, 10:56:20 AM »
Hey dude,
Good advice on the UCA's...posted some gearing info on your welcome thread too.
You are headed in the right direction, and we are here to help.  :) :)
Xrod
« Reply #4 on: May 31, 2016, 06:16:04 PM »
Well... Had one hell of a mod session up here. Day one: first things first had to wash the mud off. Then pulled my sway bars and mud flaps, blacked out all of my technicolored plastics (good ol' Wally-world rattle cans). After that I swapped in my new braided brake lines and changed my fluid. Then went down and got my tires mounted and set up for my alignment. Then had a bunch of beer ...good times! Day two: on to my suspension... installed my t-swap first everything went on great except for the fact that I was still waiting for my axles from prg(they came today, of course) so I'm 2wd for now. Then "slapped" on my deaver aal, shims, and shackles. Finally... Alignment, my guy is a wizard we were able to get everything straight and square! And then more beer!!!
« Last Edit: May 31, 2016, 06:30:51 PM by Xrod »
Xrod
« Reply #5 on: May 31, 2016, 06:20:32 PM »
Local xterras on the job
Xrod
« Reply #6 on: May 31, 2016, 06:25:22 PM »
And it still fits in the garage!!! Barely. LoL
« Reply #7 on: June 01, 2016, 07:51:04 AM »
Congrats on the sap.  You'll love it and wonder why Nissan didn't make them this way from the beginning.   I've had mine for two years now and even more insanity with taller springs and wheel spacers.  I haven't found an obstacle that I wanted to try get in my way.
Xrod
« Reply #8 on: June 01, 2016, 06:33:04 PM »
yah I don't even have 4wd yet and I love it the ride is nite and day and the clearance and travel have already made their presence known :)
« Reply #9 on: June 02, 2016, 12:13:07 AM »
planning to do 4wd conversion?
Xrod
« Reply #10 on: June 02, 2016, 12:41:49 AM »
i have 4wd standard but I was waiting on my extended axles from prg... I have them now and hope to get them in this weekend
« Reply #11 on: June 02, 2016, 08:10:56 AM »
From the above read .... correct me if I'm wrong...he didn't have a chance to install the front, extended axles, so he's currently 2wd only.
« Reply #12 on: June 02, 2016, 01:38:01 PM »
Good luck, swapping the CV's was a real pain in the A$$ and really messy.
« Reply #13 on: June 02, 2016, 04:17:06 PM »
thats where I thought he was 2wd...
Xrod
« Reply #14 on: June 03, 2016, 04:29:38 AM »
yah I'm not exactly looking forward to that part of it. Hahaha
