Author Topic: White Knuckle Sliders Group Buy! (GB is CLOSED)  (Read 45818 times)
Re: White Knuckle Sliders Group Buy! (GB is CLOSED)
« Reply #135 on: June 16, 2016, 09:43:30 AM »
You can always weld them up and never have to worry about it again.
I have thought about that too. Any idea of what that would cost?
valentin36
    • 2012 Nissan Xterra S
« Reply #136 on: June 16, 2016, 10:14:22 AM »
Hahaha this be our attempt to save a penny
« Reply #137 on: June 16, 2016, 11:59:15 AM »
I shotgunned a quote out via Yelp to local muffler/weld shops. Most are coming back around $150 with a 2-3 hour job scope.
« Reply #138 on: June 16, 2016, 12:32:52 PM »
This.
I had my Shrockworks sliders welded onto my X by Jason at ORW in San Marcos.  Cost $160, but they were s-o-l-i-d.  A good consideration esp since we all use our sliders as Hi Lift points of contact when...jacking.  :D
« Reply #139 on: June 18, 2016, 12:46:36 AM »
i have also not drilled the extra holes and have had no issues landing on my sliders, i've checked the mounting bolts a few times in the 3-4 years and they have not loosened up at all.
« Reply #140 on: June 18, 2016, 05:15:45 AM »
 I couldn't quote you a cost but I know someone who can do it and make sure it's done right.
valentin36
« Reply #141 on: June 18, 2016, 07:08:35 AM »
Did you use anything on them, like loctite or similar to it or just your hands and prayer that they don't fall off?? :o :o
« Reply #142 on: June 18, 2016, 07:44:01 AM »
If you do not plan to weld them, lock washers and some lock-tite is a very good idea.
« Reply #143 on: June 18, 2016, 08:49:34 AM »
I used lock washers, nylocks or locktite on all the bolts.
« Reply #144 on: June 18, 2016, 01:26:50 PM »
Where at?
« Reply #145 on: June 18, 2016, 01:32:19 PM »
Where at?
Give Jeremy a call at Weldtec Designs 619-596-9831. He's done several projects for me in the past and everything has been top notch.
  Here is his website: http://www.weldtecdesigns.com/
« Last Edit: June 18, 2016, 01:34:23 PM by Celt »
« Reply #146 on: June 18, 2016, 01:35:06 PM »
How many bolts does that end up being in each arm of the sliders?
« Reply #147 on: June 22, 2016, 09:28:25 PM »
Installed them tonight with the help of my buddy.
http://img.photobucket.com/albums/v408/bretdee/021F4647-99CE-4C6C-8D2C-56AF49D6F7E1.jpg
http://img.photobucket.com/albums/v408/bretdee/23311A76-B841-47CA-824D-74A519329602.jpg
http://img.photobucket.com/albums/v408/bretdee/09F44FED-DD51-4679-AB70-A3388FAB25B7.jpg
http://img.photobucket.com/albums/v408/bretdee/991FEDAC-FFE2-44CD-ADE5-DA6163DD1DF5.jpg
http://img.photobucket.com/albums/v408/bretdee/6B2FC26A-3EA5-4E92-B1B5-1DAB2B794EFB.jpg
« Last Edit: June 29, 2016, 12:00:58 PM by beedee »
valentin36
« Reply #148 on: June 22, 2016, 09:30:20 PM »
Lame guess I'm the last one to install them.. Sigh :'(
« Reply #149 on: June 22, 2016, 09:39:17 PM »
Looks good 8)
