trail pizza or GTFO
*it helps to have an oven*
The best White Pizza you'll ever have.
My White Pizza
Ingredients:
-1lb ground sausage (I get the hot stuff)
-1 box CHOPPED spinach
-1 cube pepper jack cheese
-1 bag o’ shredded mozzarella cheese
-1 Boboli crust (I get the OG thin crust…but that’s just personal preference)
How to:
Pre-heat oven to 400deg.
Put sausage in big pan. Brown that shit.
While sausage starts to brown, put box-o-spinach *CHOPPED…UR GONNA HAVE A BAD TIME IF YOU DIDN’T GET CHOPPED* in the microwave (or a bowl in a pot about 1/2 full of boiling water) for about 5min on high.
Stir that sausage. Keep it even while browning.
While waiting for ultimate brown-age and CHOPPED spinach, bust out the cheese grater and get to work on that pepper jack. You can do this prior to cooking, and it would make things 1000000x easier, but who the fuck thinks of that before-hand? Certainly not this guy…
Now, your sausage is done. Nice and evenly brown. Sweet…
Drain that shit. I use a plate. I don’t care what you use, but drain that shit. Again. No, seriously, again.
Now, *DING*, the CHOPPED spinach should be done. Grab that ghetto ass box out of the microwave and pry it open. It does not need to be fully cooked, to be honest. Just enough to smoosh. Empty box-o-spinach into ground sausage over low-ish heat. MIX. Mix that shit like a scientist. Blend. Fold. Work that spatula. Make sure it’s even.
Now drain. Again. Yeah, it’s getting old, but trust me…it’ll be worth it. Drain again. Again? You bet your ass. Again. As little moisture as possible…and that spinach shit brings the moisture.
Now, the fun really starts to pick up.
All that pepper jack you grated? Nuke that sausage with that shit! Make it rainnnn pepper jack! ALL OF THE PEPPER JACK BELONG TO THE SAUSAGE MIX. Blend. Mix. Fold. Repeat until it’s mixed evenly.
Drain. Yes, I know, you’re tired of draining. Sorry. Do it again. Drain.
Open BOBOLI thing and place crust on cutting board. Spread sausage mix onto boboli crust; make sure it’s even-steven. Use your spatula.
Now, add COPIOUS amounts of mozzarella. Handfuls. Wait, too much? NO SUCH THING. Add a little more. Make it even. Spread it around. Fill in the little gaps.
Now, slide that bad boy into the pre-heated oven at 400deg.
Give it 12min. Turn it once 180deg.
Another 5min.
Will serve 4-6.
**Warning…it’s very heavy. One to two pieces should suffice. It will hit you like a truck.**
