Author Topic: Cutting off Front Sway Bar  (Read 13735 times)
« on: October 29, 2016, 08:37:28 AM »
I'm to lazy to remove my skid plate to get to my front sway bar.
Is there any reason I can't take an angle grinder and cut my sway bar off at the closest point of the skid then undo bolt.
Basically leave the centre piece bolted on??
Re: Cutting off Front Sway Bar
« Reply #1 on: October 29, 2016, 09:08:48 AM »
If you are talking about leaving a piece of bar still in the brackets, I would shy away from that. It may eventually work its way through and could lead to some unwanted issues. If you are going to remove the bar and leave the brackets, I don't see where it would be an issue.
« Reply #2 on: October 29, 2016, 11:13:43 AM »
the sway bar is normally pretty hard material so it may take a while to cut but it could be done.  I would suggest cutting one side and pulling the rest of the sway bar out the other side vs leaving the center in.
« Reply #3 on: October 29, 2016, 02:36:09 PM »
Cutting seems like a lot of effort when it unbolts fairly easily.
« Reply #4 on: October 29, 2016, 05:43:13 PM »
On the off chance that you might want to put it back at some point, it might be best to just take it off.
Cutting it off is going to put a whole lot of sparks under there too; that front bar is pretty thick.
« Reply #5 on: October 29, 2016, 06:12:20 PM »
Just do what Jordan said.  And if after 10 minutes of cutting, it seems like a bad idea, then go to plan B 8)
« Reply #6 on: October 29, 2016, 09:16:08 PM »
Thanks Guys,
My Lazy A$$ will just do it properly  :o
« Reply #7 on: October 30, 2016, 12:26:08 PM »
Ii was able to undo all the bolts on mine and then rotate it around and work it through without removing the skid. Then reversed the process when I put it back on.
« Reply #8 on: October 30, 2016, 05:30:22 PM »
I'll give that a shot first
« Reply #9 on: October 30, 2016, 06:48:51 PM »
  Put it back on? Blasphemous....
« Reply #10 on: October 31, 2016, 09:34:51 AM »
I know I know, but I have a 15 month old daughter (and my X is my daily) and after trying it out for two days, I wasn't comfortable with the body roll. I left the rear one off though! :)
« Reply #11 on: October 31, 2016, 10:29:07 AM »
I did the same thing. Unbolted the end links and brackets, and turned and manipulated it enough to pull it out without having to take the skid plate off. But the Calmini bumper and skid plate stick out much further in the front than the Hefty one, which gave me a lot more room to work than you may have.
Even if you can't do it this way, I would think taking the skid plate off and putting it back on is an easier/less time consuming effort than cutting through two sides of it. Just my thoughts.
« Reply #12 on: November 01, 2016, 06:27:45 AM »
I hear you...I removed my FSB when I TS'ed my X...and even with all the additional articulation it provided, and with the 650 lb 2.5" extended travel Radflo's, driving the 15/78 cloverleaf as well as the twisties of Highway 76, it was an "active" driving experience.
Took a lot of getting used to and was glad I never really had to make a serious evasive steering maneuver.
« Reply #13 on: November 01, 2016, 07:48:07 AM »
  I completely understand and was just giving you a little light hearted ribbing. If you are doing most of your driving on the asphalt and haven't done a bunch of ridikillis mods leaving that sway bar on might be the best option for you. Just as Ghost said, it can make for a unique driving experience depending upon your setup.
« Reply #14 on: November 01, 2016, 09:56:13 AM »
funny you post this as I've been getting a pretty noticeable rattle coming from my disconnected, but just sitting there front sway bar
from what I've read it seems like it's easy enough to just remove tho....?!?!
