Project update 1/27/17:Well, I intended on tinkering with the project a little today, and I ended up nearly completing the entire rear axle portion. I decided that if I pull my Xterra into my garage sideways, I would be able to close down the door at night so that I can drag the project out over a couple of days (this was my initial concern with getting it all done at once - the fact that my rig would be half in/half out of the garage and taken apart). I put it up in the air and removed the rear wheels and wheel spacers, then began to pull brake parts off of the C200 axle.
I started out by disconnecting the rear brake lines on the Xterra and draining them while making as little of a mess as possible. I planned to use just the calipers and rotors, but I discovered that one side of the emergency/parking brake setup on the M226 was in pretty bad shape, including chunks taken out of the brake shoes. I'm not sure if any of you have had to work on your e-brakes before, but the setup is a PITA to work with. I didn't even know if I was going to be able to swap the parts over, but I practiced on the C200 first by taking apart one entire side and putting it back together. Once I was confident that I wasn't going to screw it up, I pulled all the bad parts out of the M226 and swapped in the parts from the C200. This one parking brake side alone probably took me about an hour and a half. Like I said, major PITA! Once that was complete, I finished moving the rotors and calipers over, as well as the hard lines that are fixed to the axle, as the ones on the M226 were bent and crushed in some places from when I transported the axle. I also installed the ABS sensors into the M226.
I then proceeded to start disconnecting everything from the C200 in the vehicle, including the drive shaft, emergency brake cables, ABS sensors, and diff breather tube. Once the axle was ready to come out, I rolled a jack under the pumpkin and removed the u-bolts and unbolted the rear ends of the leaf springs. Unfortunately, the axle ended up falling off the jack as I was rolling it out, so I ended up having to muscle it out of there with just elbow grease.
I installed the bushings in the new OME springs and put a good coat of grease and anti-sieze wherever appropriate (thanks again to RikRong for letting me borrow some). I then bolted up the front sides of the leaf springs and allowed the rears to dangle onto the floor. I rolled the new axle into position (using my better jack this time, so it wouldn't fall off) and jacked it high enough off the floor that I could bolt up the rear sides of the leafs. I then carefully lowered the axle into position and spent some time and effort working each side perfectly into position (once the center pin found the hole in the bottom of the spring perch. I then installed the u-bolt flip kit to anchor that sucker down to the leaf springs, and torqued them down to 80 ft-lbs. so they're nice and tight.
Then it was just a matter of reconnecting everything - the diff breather hose, the ABS sensor plugs, the brake lines, the drive shaft, and the emergency brake cables. It ended up taking me all day to get this much done, but it was so rewarding, and it was nice to be able to work on it at my own pace and figure things out. All I have to do tomorrow is fill the diff up with fluid and bleed the brakes (which I hate doing, but it's gotta get done). Then I'll probably start tackling the front diff.
Some photos from today:
Xterra pulled into the garage sideways and rear end up on jack stands:
Rear axle swap project
Ouch... I discovered this when I removed one of the tires. Looks like I'll be paying a visit to America's Tire once I get everything put back together:
After the C200 fell from off of the jack. You know you're not supposed to, but you always try to catch heavy things when they unexpectedly fall (and you always fail at it). Such was the case today, and I ended up crushing my left arm in the process. Stupid me:
Look Mom, no
hands axle!
All of the old stuff:
New leaf springs and bushings partially installed... ready for the new axle to be rolled into position:
U-bolt flip kit installed:
Before:
After:
And after about 10 hours of working on this, when I just couldn't do any more for the day, I remembered why I parked it sideways in the garage. The wife's car even still fits, so I don't have to hear her complain about the cold in the morning.
