Author Topic: Restoring our old off-road trailer  (Read 10918 times)
Re: Restoring our old off-road trailer
« Reply #15 on: March 06, 2017, 08:18:53 AM »
Looks great Tony...where did you source the new axle?
« Reply #16 on: March 06, 2017, 06:36:16 PM »
Not to jump in on Tony, but, I've had great luck getting stuff at a good price from etrailers.com.  Good pricing and quick shipping.
« Reply #17 on: March 07, 2017, 07:06:10 AM »
I got everything but the axle tube at San Diego Trailer Supply on El Cajon boulevard just west of 70th Street in San Diego.  The spindles, brakes (10-inch electric), drums, brake controller, bearings, and new u-bolts/plates came to about $450.  I got the axle tube (2-inch square, 1.4" wall thickness, five feet long) at Industrial Metal Supply in Kearny Mesa for under $25.  After notching one of the spindles so it would slide into the tube, I welded it in place.  Then my son and I assembled one side and put it under the trailer.  After a little trial and error with the tire mounted, we figured out where to put the indexing holes of the spring pads.  We used the larger 285s for measurement so we can upgrade to that size once we wear out the 265s.  Then we completed the other side and mounted it all up.  Not bad for five hours of quality time with my son, including pizza and beer for lunch!
« Reply #18 on: March 07, 2017, 07:52:29 AM »
Thanks Tony & Tim...sources noted.
Tony...what vehicle is peeking around the corner with the ARB front bumper...looks like a LR, maybe a Disco?
« Reply #19 on: March 07, 2017, 08:06:16 AM »
That is my '95 Disco.  Motor needs rebuild, plus a load of other annoyances.
« Reply #20 on: March 21, 2017, 07:06:34 AM »
More photos added on page 1.
« Reply #21 on: March 21, 2017, 07:26:38 AM »
That's lookin really good. Are you going to do a battery bank/solar/water tank set up with it?
« Reply #22 on: March 21, 2017, 07:35:46 AM »
It's a possibility.  Right now I'm using the plastic jerry cans for water and I have a Goal Zero battery/inverter that would be easy to just plug a panel into.
