Author Topic: CANVAZ VIII 2018 (Official Thread)  (Read 75788 times)
Syberia
    • 2005 Off Road
Re: CANVAZ VIII 2018 (Official Thread)
« Reply #120 on: August 19, 2018, 11:46:10 PM »
YouTube doesn't make Calcite Mine seem that bad but I think I'll pass this time.
Sent from my Moto G (5) Plus using Tapatalk
« Reply #121 on: August 20, 2018, 04:23:57 AM »
 Calcite Mine is a classic Anza Borrego run with a lot of history and amazing views. It's not very difficult all in all and we are going through other washes getting there and out through Font's Point which is something not to be missed out there. It's your choice but I personally think you may be missing out on a really great run.
Syberia
    • 2005 Off Road
« Reply #122 on: August 20, 2018, 07:38:40 AM »
I have a stock 2005 O/R but almost no experience.  Only trails I've done so far are Santiago Peak (did the whole thing at like 5 mph because I didn't deflate my tires first so it was bumpy as hell...), and some rutted gravelly mess in the Mojave that my GPS thought was a road.  If you think that's enough, I might be willing to give it a try.
On that note, guess who gets to fix their axle/pinion seals before the trip :(
« Last Edit: August 20, 2018, 07:50:18 AM by Syberia »
« Reply #123 on: August 20, 2018, 08:15:33 AM »
CMT (Calcite Mine Trail) has a couple of sections that require careful spotting and use of your factory locker.
If you choose this run, place yourself back in the queue so you can watch how others take successful lines up the first obstacle.  It is a seriously rutted section of off camber bumps, that usually puts a stock Xterras sway bars and suspension to the test.  Bring a camera/charged smartphone, as the likely-hood of some "three-wheel" photos is high here.
You won't have issues following your trail leaders guidance, airing down to at least 18lbs. PSI, and following through the fun obstacles this run has to offer.
Spotting tip:  folks should be guiding you with "driver/passenger" as opposed to "left/right."  Also, a quality spotter never uses the command "straighten it out..." as you can't see your wheels orientation from the driver's seat.  Spotters should always be guiding with either the "passenger" or "driver" command to get your wheels straight and back on track.  Spotter/driver communications should calmly build a sense of confidence and trust that often results in friendships that last a lifetime...
Have fun, and Celt is correct...the history of this trail, combined with the views from the top overlooking the Truckhaven Hills and Anza Borrego Badlands shouldn't be missed.
Syberia
    • 2005 Off Road
« Reply #124 on: August 20, 2018, 08:16:56 AM »
Maybe I didn't see those parts on YT.  I think I'll pass.
« Reply #125 on: August 20, 2018, 08:43:11 AM »
Didn't mean to scare you off this run...I think you'll be fine.
But, we haven't personally met, this IS the internet, so caveat emptor!
CMT isn't a casual drive across a parking lot for sure...but that's where the adventure begins!
SocalTerraX
    • 2007 Xterra
« Reply #126 on: August 20, 2018, 10:09:09 AM »
I'm interested in this trip. Need to read up a bit more on the context. Thanks
« Reply #127 on: August 20, 2018, 02:09:26 PM »
Welcome
Introduce yourself on
https://www.sccxterra.com/smf/index.php?board=15.0
Syberia
    • 2005 Off Road
« Reply #128 on: August 20, 2018, 10:33:36 PM »
I think id rather stick to 4 wheeling for the time being, maybe I'll dabble in 3 wheeling another time.
« Reply #129 on: August 26, 2018, 09:24:32 PM »
Just to make this clear since im not the only with this concern now. As many know now that I got a new truck 4wd. I do intent to attempt some trails but with my concerned wife and new truck on hand,Can I stick to just the camping part? Not really considering trails to prevent any argument with the wife n such. If this is the case, then Im still in, if not then I will have to pass til I get a capable rig where I might just run solo.
« Reply #130 on: August 26, 2018, 09:30:22 PM »
You literally can do whatever you want.
Sit there, go on trail runs, make a cheesecake in the dutch oven, go over where DRV is and shoot at targets or rocks. - it doesn't matter.
« Reply #131 on: August 26, 2018, 10:03:12 PM »
DRV??
well with that said, I can feel much more comfortable now.
« Reply #132 on: August 26, 2018, 10:07:19 PM »
DRV??
DRV = Desert Rendezvous.
Remember, it was windy?
« Reply #133 on: August 27, 2018, 04:31:14 AM »
  If you decide to just camp that's fine you can do whatever you want to do there is no pressure otherwise. The way these trails are being planned is they will range from difficult to very easy. We do this to allow for experienced drivers in built up vehicles can have some challenges. The easier trails are designed and get people out there on other trails to have fun learning about off roading and the area when they go back.
Syberia
    • 2005 Off Road
« Reply #134 on: August 28, 2018, 12:30:49 AM »
Well now that you mention it, I am volunteering my wife to bring cheesecake for the potluck
