Author Topic: First shakedown with the X- Tripps Flats  (Read 9850 times)
MotoTech81
  • 4wd Pts: 1220
    • 2003 XTerra SE 4X
« on: December 17, 2019, 09:50:22 PM »
As we approached the OHV sign with the Black “Most Difficult” picture on it, my wife asked .. “Does the 4WD work?”    ???  It was at that moment I realized I bought a used 4X and never checked if the 4WD worked...  Of course I lied and said yes, and that maybe they should hop out and walk up in trail for photos..   luckily 4Low got a good workout and with open diffs, momentum was key! Had a great time though and looking forward to removing the rear sway bar and throwing some more Swag at it. [ You are not allowed to view attachments ]
Re: First shakedown with the X- Tripps Flats
« Reply #1 on: December 18, 2019, 06:59:34 AM »
Looks like a fun time
« Reply #2 on: December 19, 2019, 10:22:09 AM »
Nice shakedown run! I've never done Tripp Flats, just the Thomas Mountain side of those trails.
MotoTech81
  • 4wd Pts: 1220
    • 2003 XTerra SE 4X
« Reply #3 on: December 19, 2019, 08:14:00 PM »
Oh yeah,  Thomas Mtn would be a good run. I’ve camped up there years ago on moto’s.  Tripp flats is fun but it’s a pretty short run. Good shakedown though to see what (doesn’t) work!
« Reply #4 on: December 22, 2019, 11:32:44 AM »
1st gens pretty much all have a limited slip in the rear end which helps a ton, the 00-01 were the best because they had a higher initial torque but the 02-04 were still acceptable.
Glad you and the family had a good trip.
MotoTech81
  • 4wd Pts: 1220
    • 2003 XTerra SE 4X
« Reply #5 on: December 22, 2019, 05:33:27 PM »
Oh cool, good to know. I was wondering why it performed better than an XJ I used to have.  Im gonna pull the rear swaybar this weekend and see if I can gain a little articulation. Thanks for the info!
Rogue Overland
  • 4wd Pts: 16441
    • 2001 SAS Xterra /2002 Xterra / 2012 TS Xterra
« Reply #6 on: January 31, 2020, 10:48:33 AM »
Looks like a good time!
